Topic: 88 TC- V8 swap (Read 9856 times) previous topic - next topic
88 TC- V8 swap
I'm pretty sure you just need the cam, heads, and upper intake to make it an HO. Oh, and the computer.
FirstBird, I think it is a Sport. It has the Sport/TC interrior.
88 TC- V8 swap
Quote from: 1Bad88tbird;398866
 No MAF conversion necessary?
88 TC- V8 swap
Be careful with the cam, standard 5.0's don't have valve reliefs.
95 Ranger Splash 2.3
88 Tbird Sport :ies::ies:
88 TC- V8 swap
It's an '87 Sport, but someone swapped the seats and door panels.
88 TC- V8 swap
Quote from: BlackTHUNDA;398865
Nice!
What do I need for an HO swap?
What about gt40 heads and intake? What else is needed for proper installation?
I know nothing about the standard output 5.0
I'm learning as I go, been searching all morning.
Basically everything except for the rods, crank, block & lower intake are different, includes heads, injectors, upper intake, throttle body, etc... ... The flattop pistons have been mentioned and some have used the HO cam on E7 heads without valve clearance issues...
With stock pieces it'll run fine with the speed densety(in fact the stock '87 & '88 SD Stangs were the quickest of all years)... If you go with a better set of heads(highly recommended over anything stock) & rumpty cam, then it will no doubt need to run a mass air setup...
BTW the Trick Flow heads can be used with flattop pistons, I have a '86 HO short block in mine without valve reliefs and never had a issue...
88 TC- V8 swap
Most people I've seen do not have issues when using E7's/HO cam with the stock SO flat-tops. The E7 heads increase compression on an SO motor because of the flat top pistons, and it will actually run stronger than a stock HO will.
Why not drop in a Explorer 5.0? That way you get the much better GT40 heads to start off with.
88 TC- V8 swap
Only the 1996-Feb 1997 exploder 5.0 have the gt40.  The mar97-2001 have the GT40p heads....just to clarify.
Travis
88 TC- V8 swap
All you need to run the "P" heads are BBK shorty headers. You don't need the ultra expensive Motorsport headers.
88 TC- V8 swap
Thanks for all the input guys.
The 5.0 from the explorer is sounding way better than the HO conversion. What will I need in order to achieve this swap?
88 TC- V8 swap
Reply #39
-Better than Explorer cam
-Upgraded valve springs
-Oil pan and pickup
-dip stick and tube
-timing cover and appropriate accessory brackets
-distributor
-Fox valve covers and a set of gaskets for them
-water pipe for lower intake
-water pump
-timing pointer
-new gaskets and front/rear seals
-Heater hoses, radiator hoses, water hoses up front from the waterneck and thermostat housing to the water pump
-Thermostat housing
-one piece oil pan gasket
-fuel rail
-injectors
-Motor mounts
-Appropriate harnesses
-throttle cable
-fuel lines
-Block plate
88 TC- V8 swap
Reply #40
Quote from: vinnietbird;399001
-Oil pan and pickup yes
-dip stick and tube  yes
-timing cover and appropriate accessory brackets  yes
-distributor yes
-Fox valve covers and a set of gaskets for them yes
-water pipe for lower intake  yes
-water pump
-timing pointer yes
-Thermostat housing yes
-fuel rail yes
-injectors
-Motor mounts
-Appropriate harnesses yes
-throttle cable yes
-fuel lines yes
-Block plate
Most of the above parts can be sourced from the SO 5.0 in the parts Bird...
88 TC- V8 swap
Reply #41
Quote from: TurboCoupe50;399008
Very true. And as stated above I believe, take VERY good care of the floor shifter, cable, and bracket from the Sport. Also the shift linkage if you're using an AOD but not that one. Those parts are hard, and almost impossible to find.
What trans are you planning to use? The motor mounts from the Sport will be needed as well. If you have any questions, we're here.
88 TC- V8 swap
Reply #42
Ford actually sells a kit for their crate engines that has all the needed engine parts to put an Explorer motor in a Fox. Oil pan, pickup, timing cover, water pump and even a new balancer, this is what I used. :)
88 TC- V8 swap
Reply #43
It is not a Sport but a Thunderbird LX. In 87 you could order a LX with a floor shifter and Turbo Coupe seats in Raven (I have seen a mint 23K mile example of this at a VTCI convention). For some reason in 87 the Sport got the base Thunderbird interior with a floor shifter but the LX had the optional TC seats. In 88 the Sport got he TC seats and they couldn't be ordered on the LX.
Lest you think I'm making it up this is documented in the Standard Catalog of Thunderbird (which I own a copy of) and by looking at dealer order books from 87 (which the 87 LX T-bird with raven TC interior's owner had). I know it's weird but I guess someone at Ford thought it was a good idea. Not very many LX cars came like this and if they did they were full optioned cars with leather. The cloth seat LX cars were equipped similarly (no TC style seats) in 87 and 88.
88 TC- V8 swap
Reply #44
Great info guys, thanks.
