Topic: 88 TC- V8 swap (Read 9862 times) previous topic - next topic
88 TC- V8 swap
Quote from: turbotrav;388570
Welcome....Nice TC.
You may want to checkout http://www.natomessageboard.com for TC specific repairs.....Also a really nice website.
Travis
Cool thanks
88 TC- V8 swap
Found these on CL for 200 bucks and thought they would look good. 03 Cobra 4 lug replicas. I need to get better tires all around. Maybe 245/45 for the front, and 275/40 or 285/40, I don't know how wide I can go. I know I have to get the fenders rolled which I will do before buying new tires. Does anyone have 17x9's? What size tires are you running?
88 TC- V8 swap
Looks good....Its real convenient that our cars share mustang wheels and other bits....gives us lots of inexpensive options.
Travis
88 TC- V8 swap
Quote from: BlackTHUNDA;393167
My current wheel and tires sizes:  255/40-17 on a 9" rim & 315/35-17 on a 10.5" rim.
Looks like those front tires are way under sized for the rim!
88 TC- V8 swap
I have 255 40 17 on the front (9 inch rims), and 275 40 17 out back on 10.5 inch rims.
88 TC- V8 swap
Quote from: 86T-bird;393175
Indeed.
88 TC- V8 swap
The front tires were definitely undersized. The outer rim stuck out away from the tire :wtf:
I went with some 245/45/17 up front same as the rear. I be changing the rears to  275/45 or 40 In the next couple of days.
88 TC- V8 swap
So I decided to swap in a 5.0.  I bought an 87 T-bird that looks like shiznit, it has a 5.0 with an auto trans. I might even go with the auto trans for a while. The engine sounds and runs smoothly.
Here's the donor. It has a lot of good parts too!!!
The car was wrecked in the front. Everything is crooked. It was going to get sped.
88 TC- V8 swap
You'll loose power over your 2.3 turbo, unless you're just using the 5.0 harness and will be dropping in a 5.0 HO.
88 TC- V8 swap
Can I have your Turbo coupe side door emblems... for a price of course..
1988 Thunderbird Turbo Coupe - Black - 5 Speed - 181k Miles
1989 Chrysler LeBaron Conv - Silver - Auto - 24k Miles
1993 Thunderbird LX 5.0 HO - Silver - Auto - 72k Miles
88 TC- V8 swap
Quote from: FirstBird;398825
I will go with the 5.0 HO eventually. I was looking for a mustang donor car, but they were either in to great of shape to destroy, or to expensive. I got this junker for 300 bucks. Not bad considering all the parts.
So yes, a 5.0HO will go in this thing down the road.  And I'm aware of power loss.
Does anybody now the specs for this year 5.0?
88 TC- V8 swap
Quote from: KnightHawk;398831
Sorry bro, but I'm planning on running a turbo V8 later on.
88 TC- V8 swap
Quote from: BlackTHUNDA;398838
Yeah that donor is a Sport & has the HARD to find AOD floor shifter, the A4LD TC shifter is different(seven positions vs six and cables are different), can't be used...
On a good day the wimpy SO 5.0 makes 155 HP...
When I converted mine I used a built 5.0 with Trick Flow heads, cam, 1 5/8 headers etc, defiantly more fun than any of the  real TCs I owned...
88 TC- V8 swap
I don't believe that's a Sport, I think Sport t-birds had all black trim around the windows like Turbo Coupes. When you s the car try to salvage as many parts as you can. Everything is getting harder to find these days.
88 TC- V8 swap
Quote from: TurboCoupe50;398849
Nice!
What do I need for an HO swap?
What about gt40 heads and intake? What else is needed for proper installation?
I know nothing about the standard output 5.0
I'm learning as I go, been searching all morning.
