Topic: pulling motor (Read 2130 times) previous topic - next topic
pulling motor
I'll be pulling the motor out of my friends turbo coupe. I am wondering what i need. I know i need a hoist and engine stand but is there anything else. A post on craigslist had a hoist and a "Come along". I am not sure what a "Come along" is. do i need it?
pulling motor
Tools. You'll need tools.otherwise, postpone the work until you get tools.
pulling motor
I never used a come a long pulling an engine. i DO put two space saver spares on the front and raise the rear of the car for a better angle of attack once everything is unbolted and ready to pull.
pulling motor
a leveler comes in handy when pulling motor and trans.. my guess is, they were using the come-along to act as a ghetto leveler.. HD ratchet straps do the job quite nicely, too
pulling motor
Quote from: Shadow;384829
I used a come along last time I put the HO in the Sport...busted the dist. cap and the rotor. Next time I'll try it the way Vinnie says.
pulling motor
With the rear raised and the tiny tires up front, the engine just came right out
pulling motor
my biggest pet peive with these cars is the fact that the upper rad support is welded to the car.. this is something i hope to change to make life easier lol
pulling motor
I've also thought of that. If the upper core support was detachable, the engine would literally slide right out (with a slight lift and removal of the header panel). We cut the core like that on a parts car and it made engine removal a breeze.
pulling motor
time to attack my car with the sawzall!! AGAIN!
pulling motor
Don't forget, on our cars, it's basically a structural element..
pulling motor
You'll need long bolts to go through the engine stand mounting points to the block. The bell housing bolts are no where near long enough. Sandwich bags are great for putting nuts and bolts in. Label them with a sharpie too. I pulled the engine out of my parts car a few weeks ago, so those are the biggest thing that comes to mind.
2002 Honda Civic EX
1984 Ford Thunderbird Elan
5.0 CFI, T5, Dual Exhaust
pulling motor
I laid a plastic sheet under the car, then absorbent pads on that. No fluids on the concrete at all.
pulling motor
Quote from: Shadow;384840
More of your half ass repairs eh...
I dropped the 5.0 and AOD in as a unit in my TC no issues, it'll come out the same way...
pulling motor
Quote from: ThunderbirdSport302;384844
same as durangos, but they're bolted in securely enough.. i'm not going to attempt it without some serious thought, planning and a little added reassureance.. don't want to watch the lower support fold in half after i cut the top off LOL
Quote from: TurboCoupe50;384887
wah wah wah is all i hear.. get off my nuts
pulling motor
Make or buy a motor plate makes pulling and installing much easier.
87 TC
