Topic: Automotive engineers.....What do they know? (Read 6444 times) previous topic - next topic
The purpose of this thread is to list engineering mistakes with no regard to nameplate. I'll start. I have seen vacuum tanks made out of thin plastic and mounted on the bottom side of car. No...that will never get broke. How about oil filters mounted in the wheel well. Wheels tend to pick up sharp rocks and hurl them at the filter. One of my favorites.. batteries mounted in the wheel well. They do use liners to protect the batteries, but as for testing and or replacing the battery you are required to remove the wheel. How convenient!:toilet:
how about dodge's long-running issue with the neons and head gaskets? lol and the fact that part of a stratus's 30k mile tuneup was bars leak tablets you drop in the radiator.. pretty big engineering fail on both counts, for not fixing the problems ahead of time..
On the headgasket note, how about gm's 3.1 - 3.4 intake gasket issue that eventually takes the headgaskets out
And lets not forget dodges tranny issue's. I think it was discovered the passages were not big enough and over heated the trannys
took them way too long to figure out their trans issues..
and to add to the stupid battery locations.. how about buick with the battery under the back seat? pretty friggin stupid idea in my book, even if they are 'sealed, special batteries'
F-ing TV cable bushings!!!
I got a few:
Ford's infamous ign switches.
3.8 Esshag headgaskets.
Ford probe
Yugo
Jeep (AMC) model 20 rear ends (2 piece splined hubs on the axle shafts=weak as hell)
A4LD trans in the TC
10" brakes on a Fox CatBird stock
1989 and up Tbird (not really, but I do NOT care for 'em)
I can add more...but too tired and drunk to think of more.
The 2.0 head gasket issues were not limited to Neons. Stratus, PT Cruiser (Part Time Cruiser), and Avenger had same issue. Their fix was a multi-layer steel head gasket. PT Cruisers are the worst to fix. Their weird shape makes repair difficult. Motor mount that attaches to front cover can not be removed with the head on engine. Can not remove head without removing front cover. Have to wedge motor mount into the fender.
What about chevy putting the battery by the spare tire in the HHR, because they didnt leave enough room under the hood. If that battery explodes the trim back there is pretty much ruined
Quote from: Chrome;376445
lets just sum it up in 1 word.. or name.. DODGE
Didn't know about battery location on HHR. I don't like that at all. I have had a battery explosion twice. I felt lucky because both times the hood was closed and I was inside the car.
Neons period. Figured a more economical newer car would be worthwhile. Got worse then my bird freeway snd close to the same city. I married into it, I didn't buy it. With the money I put into to it in two years, I could have had a pretty nice cougar/bird. I actually put more money into that car then I have into everyone before, and after over about 8 years.
2nd gear in the GM 700R4
Overdrive in the AOD
The A4LD
The trans in '90s Tauruses.
The stereo in '88-'94 Chevy trucks
Matt
Quote from: Chrome;376454
 Only reason I know is Im in college for Auto Tech and one of the biulders is an HHR. Thinks have small windows and very little room for a guy my size 6'5"
The engineers don't get the final say, the bean counters do. They're forced to design "good enough" or "that'll do".
^^^^^ Mankind is plenty capable of building...THINGS that are very robust. Cost is always the governing factor.....and then people blame the guy that built it, not the one that told him to build it. Such is life :giggle:
