Topic: So what does your fox look like today!!!!! (Read 210605 times) previous topic - next topic
Reply #495
I have seen the name on offroad racing trucks but don't know much about the tires. I am trying to decide what to put on my 10 hole wheels. I am going to go with 225/60s all the way around. I was thinking about getting BFG Radial T/As. I can get T/As for $125 each mounted and balanced locally. The 295/50 fills out the wheel well nice.
86 T-Bird V6 C5
91 F-150 5.0L 5spd
93 Mustang LX 351C C4
2013 Honda CRV AWD
Reply #496
If they had 275/50/15 I would of got them these are a little too big, but hey say bigger is better, lol
1986 T-bird
347 stroker motor
185 AFR Heads
TrickFlow cam 224/232-542/563
Victor Jr. intake CNC ported
Quickfuel Holley 800 cfm
Hooker 1-3/4 long tubes
Custom built AOD
B&M 3000 stall
8.8 w/4.30 gears
UPR upper/lower control arms
Strange shocks/struts
26x10x15 M/T slicks
11.48@119.27
(coming soon Tremec 3550)
The Finished Product
Reply #497
That's what they say. They are big tires. It is interesting that one tire manufacturer will have a 295/50 but not a 275/50. Another manufacturer will sell a 275/50 but not a 295/50. BFG sells a 245/60 were most tire manufacturers don't. You wonder what the method to there madness is.
86 T-Bird V6 C5
91 F-150 5.0L 5spd
2013 Honda CRV AWD
Reply #498
I know they have 5 different drag radials in the 275/50 but no street tires seems to me it's a popular size
1986 T-bird
347 stroker motor
185 AFR Heads
Custom built AOD
B&M 3000 stall
8.8 w/4.30 gears
26x10x15 M/T slicks
11.48@119.27
Reply #499
No doubt, I agree.
86 T-Bird V6 C5
91 F-150 5.0L 5spd
2013 Honda CRV AWD
Reply #500
dirty, but driving the snot out of it, probably put 1000 miles on it this week.  glad the dents fixed and stereo finally is up to par. just in time to put it away for the winter.
-pete
july/88 turbo coupe auto
Reply #501
^^^  Nice car......clean looking!
1988 T-Bird Sport Coupe--5.0 HO, MAF swap, 1-5/8" shorties, BBK/Flowmaster exhaust, Explorer intake, 70mm Edelbrock TB, T5, B&M short throw, Centerforce clutch and PP, disc brake TC rear w/ 3.55's, TC front brakes, '98 Cobra springs, DIY SFC's, other misc .  14.05 @ 98mph with launching too low and shifting too high.
Reply #502
Quote from: 347Thunder;400542
Got dome new shoes 295/50/15
That's it!  I'm putting my stock springs back in the rear so I can go to a larger tire!  Running 245/60's now and they rub when someone is setting in the back seat.
 That is a super sweet ride.  Did you just leave off the side molding from the front bumper to the rear bumper?
Reply #503
Quote from: Dan B.;400858
Have you thought about swapping your axles with mustang axles (they are 3/4" shorter).I am running p255/60r15 in the rear w/4.500 backspacing.
Reply #504
Quote from: Chooglin;400862
Hadn't thought of that. Can it be done with the TC rear w/ disc brakes? That what I'm running.
Reply #505
Yes I made some aluminum pieces for the transition.
1986 T-bird
347 stroker motor
185 AFR Heads
Custom built AOD
B&M 3000 stall
8.8 w/4.30 gears
26x10x15 M/T slicks
11.48@119.27
Reply #506
Quote from: Dan B.;400863
IDK...........maybe someone with the answer to that, can chime in.I have drum brakes.
Reply #507
Hey Dan I kept my drum brakes when we put the TC rear in. We had to cut some of the mounts off from the rear disc set up but then just put the drums back on. I have axles from a 91 Mustang Gt in it now. Even with the 7.5 axles in it and being lowerd my tirse were rubbing the inner fenders. But with the mustang axles it was better. Now I'm back to stock height.
Reply #509
Love the stance!!
95 Ranger Splash 2.3
88 Tbird Sport :ies::ies:
