Topic: So what does your fox look like today!!!!! (Read 224292 times) previous topic - next topic
I figured this would be fun to see where everyone is at on their builds, I'll start:
:punchballs:
1986 T-bird
347 stroker motor
185 AFR Heads
TrickFlow cam 224/232-542/563
Victor Jr. intake CNC ported
Quickfuel Holley 800 cfm
Hooker 1-3/4 long tubes
Custom built AOD
B&M 3000 stall
8.8 w/4.30 gears
UPR upper/lower control arms
Strange shocks/struts
26x10x15 M/T slicks
11.48@119.27
(coming soon Tremec 3550)
The Finished Product
My pic would not be very exciting...the car is in the garage with a car cover on it.  Hopefully I can take it to the big carshow that is part of my hometowns annual fall festival this weekend.
As of this moment:
XXX
Here's mine, drives great after all the suspension mods!!:bowdown:
95 Ranger Splash 2.3
88 Tbird Sport :ies::ies:
Quote from: cougarman;369264
Your car is coming along very nicely!  Are you still running the stock rear control arms?  I like the stance on your car.
Just brought it home from paint still need to clean the interior and put door panels and hope I have no more bugs to work out. Some one improperly put the u joint together and I almost put the drive shaft through the floor today
Quote from: 50tbrd88;369268
Thank you, yes I'm running the stock control arms with TC springs and '04 Cobra springs in front. I'm kinda "old school" I like a little rake...lol.
still looks like this.... would've had the starter wired today, if i didn't leave my electrical tools on the job today...
Looks like it'll get wired tomorrow...... And then, You know what happens after that..........
Daminc, goodluck
looks like this
Quote from: thewestie;369271
Westie!!!!!
It's beautiful!!
Quote from: thewestie;369290
Daminc, goodluck
Thank you
Thanks Flylear I'm hoping to get some help uploading some pics I took along the way. It wasn't as bad as Damincs build but it was enough for me :)
Uummmm....I drove it into the garage on Monday at about 4pm.....and here is what it looked like by 9pm.
The SO 5.0L is on the ground supported by the engine hoist.  The HO 5.0L is on the stand awaiting an accessory drive swap then in it will go.  If I didn't have friends coming in on Thursday....well, today I guess, and staying for a few days I would probably have it together by Friday.
1988 T-Bird Sport Coupe--5.0 HO, MAF swap, 1-5/8" shorties, BBK/Flowmaster exhaust, Explorer intake, 70mm Edelbrock TB, T5, B&M short throw, Centerforce clutch and PP, disc brake TC rear w/ 3.55's, TC front brakes, '98 Cobra springs, DIY SFC's, other misc .  14.05 @ 98mph with launching too low and shifting too high.
they should be great help, I think you should have it in late today!!!!
1986 T-bird
347 stroker motor
185 AFR Heads
Custom built AOD
B&M 3000 stall
8.8 w/4.30 gears
26x10x15 M/T slicks
11.48@119.27
