Topic: My 87 LX (Read 107419 times) previous topic - next topic
My 87 LX
Reply #120
Im hoping to put a coil cover in and cover those wires. and thanks
My 87 LX
Reply #121
What has to be done when you take out the stock fuel gauge? Is it just a straight swap?
My 87 LX
Reply #122
it can be. depending on what youre doing. I ran all new wires but you can splice into the gauge harness and wire it however. but be careful what gauge you run if youre using the stock sending unit.. I think ours are 33/240
My 87 LX
Reply #123
Oh those guages look killer. did you end up having to cut the dash face trim to get it to fit over your oil guage in the corner? I'm wondering because I will have to do the same with mine when I go fully custom. I've redesigned my layout 3 times and sat for hours trying to fugure out a way to get everything to fit without having to go down to a lower size guage set than I want but it's not possible. $800 for a set is frikken crazy but I feel your pain... that's the only reason I haven't gone fully custom yet on mine is cause of the $450 it'll cost me for the set that I want to use.
My 87 LX
Reply #124
I actually trimmed out from under the gauge about 5/16-3/8 from the face of the panel. It was a royal PITA to get the gauge into that perticular spot. it was a 2thumb job. the others were a peice of cake. I would,however,if someone else were going to do this advise to try and get the outer gauges further away from the tach and speedo.
My 87 LX
Reply #125
yeah mine will be totally custom, so it will be all enclosed guages. As long as the faces don't sit on top of each other I'll be fine. I even contacted Auto Meter to make sure everything will fit good
My 87 LX
Reply #126
steve, are the lines where you'll be cutting? if so, they're not going to fit
My 87 LX
Reply #127
The circles are the outermost point of the guage faces. The asterisks are just a result of a lot of measurements for the center points of my radiuses for the layout. and the crosses are where I will be putting screws to hold down the sheet metal that will be going on the face of the cluster to smooth everything out. And don't worry, I've got plans to get around the not fitting part of the process. That is why I was curious what Blackjack did if he had to cut his surround or not b/c you can see from my circles that I will definitely have to. It wouldn't be so bad but if you look at the surround, it starts to dip down as it gets closer to the left side at the top. All the factory clusters are actually cut for that stupid curve. Which is stupid. Did I mention that stupid curve is stupid?
My 87 LX
Reply #128
agreed on the curve.. that's why i use aluminum sheet metal and spray it with 'wrinkle finish' paint, for customers that want that 'semi-stock' look.. then just cover it with some 1/8" plexiglass.. it's also much easier to be cutting something up that i don't have to search the junkyard for, if i slip or screw up lol
My 87 LX
Reply #129
If you run 2" gauges you wont have to cut the surround. all my gauges fit neatly under the stock gauge lense.
My 87 LX
Reply #130
Ode to shadow. He haaaaaad to bring up the wires.
and I threw the trunk panels in to mock up what Im going to do about the cell, battery and how Im going to TRY and hide some stuff.
My 87 LX
Reply #131
Quote from: 87thunderbirdBlackJack;382636
*sigh* much gooder!
My 87 LX
Reply #132
How big is the cell?
My 87 LX
Reply #133
15 gal.
A small update. I built a tray for the battery box to fit in and undercoated the trunk, filled all the holes and all that jazz. No pics but Ill tell ya it looks  good.
My 87 LX
Reply #134
Got most of the battery relocate wiring done, got the fuel lines ran, waiting on rear springs, going to continue wiring in the Ignition, fan and staginglock Trunk is somewhat back together but not final until I get some shocks and other assorted goodies as in my sub box, and various wiring done. but shes comming together.
