Topic: The CP autox bird (Read 123785 times) previous topic - next topic
The CP autox bird
Reply #330
Not sure how I'm going to get a downpipe through here yet.
And there is more room to the strut tower than I thought there would be which makes me HAPPY!
The CP autox bird
Reply #331
Just noticed the aluminum head
Who makes that ?
The CP autox bird
Reply #332
Its and Esslinger D-port with the BoPort stage 3 porting with his 2.1 cam and solid roller conversion.  It washiznitting the 8500rpm limiter last year fairly regularly.
The CP autox bird
Reply #333
 that thing spins lol
The CP autox bird
Reply #334
Intercooler pipe rerouted to turbo
Managed to get the exhaust through there.  Not finished, but good enough till I get it on the lift.
Had to redo the turbo intake too.  Biggest problem was keeping the 52mm restrictor in there but its all in there and clearing.  Just have to remake one breather tank hose.
My biggest fun of the day was swapping out pedal assemblies to go from the TC hydraulic setup to the mustang cable clutch.  What a PITA.
I love how this u-joint says not for street use on it, lol
The CP autox bird
Reply #335
Great Work!
The CP autox bird
Reply #336
I'd love to hear this thing screaming up to 8500 rpms.
The CP autox bird
Reply #337
Love the work you're doing !! :D
86' T/C 4.6L DOHC
16' Chebby Cruze 1.4L Turbo
“Heavy Metal Mistress”
[/COLOR][/SIZE]
The CP autox bird
Reply #338
Finally got it started tonight.  Runs great on locked timing.  Of course I'm going to have an issue with the commanded timing with the spout.  As soon as I put the spout in, the timing jumps all over the place between about 10* before TDC to 25* ATDC.  Even with this problem showing up, I can tell its going to be a screaming setup!
I've been trying to upload a video to photobucket from last year running near or above 8000rpm for a lot of the run, but keeps screwing up.  Going to try youtube later.
The CP autox bird
Reply #339
Very nice man that is a nice set up
I like how every thing is custom mounted
The CP autox bird
Reply #340
Ok, got the timing fixed.  Went to work on it at lunch and had a no start.  Nothing like a broken signal wire from the tfi to start off with.  Got that fixed, and then back to work.  Thought about it all afternoon and then it dawned on me that when I finally got the megasquirt to actually control the timing, I couldn't set it with the spout out.  Had to do it with the spout in, so now its running the way its supposed to.  Also got all the coilover springs changed tonight.  Just have to finish filling the coolant, and get it off the stands so I can finish the exhaust on the lift.
The CP autox bird
Reply #341
Nice..that's beautiful. Can't wait to see more...and a vid too. :)
The CP autox bird
Reply #342
Think I killed my camera today, so vids will have to wait unfortunately.
The CP autox bird
Reply #343
I'm loving this car more and more
Seems like you have the knolage and mean to make a bad ass car
Wish there was a way to see it in person
The CP autox bird
Reply #344
Quote from: STANG8U;412990
I'm loving this car more and more. Wish there was a way to see it in person
I know what you mean. I wanna ride in it :evilgrin:
86' T/C 4.6L DOHC
[/COLOR][/SIZE]
