Topic: The CP autox bird (Read 123552 times) previous topic - next topic
The CP autox bird
Pretty much have the panhard bar and mounts done.  Just have to take it all out to finish welding and gusseting.  Welder was giving me fits all afternoon and don't know why.  It is getting low on wire so that could be it.
The CP autox bird
that's an interesting panhard bar setup, looks great though, nice and parallel with the rear
The CP autox bird
little update
Had to put this in to see how much clearance I had to build my torque arm
Had to cut shifter hole since it was an auto car
proposed ride height :thumbsup:
torque arm crossmember
The CP autox bird
open DP?
The CP autox bird
doesnt have any downpipe on it yet.  I haven't done ANYTHING to that engine yet.  There is still room above the torque arm crossmember to be able to get a 3" pipe though there though.
The CP autox bird
Quote from: fordguy545;348178
That is what I was wondering. Difficult to tell from the pics if there is enough room above the xmember for any piping
The CP autox bird
It will have to go to the side of the transmission tunnel though, but it will go through.
The CP autox bird
Just enough room to still get a 3" exhaust through there.  I will probably clearance that brace for the seatbelt though.
The CP autox bird
what part numbe is that rear coilover kit?
i didnt find anything on bilstein site for mustang or t bird
thanx alot
The CP autox bird
Reply #39
they are from maximum motorsports for SN95 mustang.  Bilstien sport valved shocks in the rear and eventually get sport front struts too.  current ones are standard HD bilstiens.
The CP autox bird
Reply #40
torque arm done :thumbsup:
The CP autox bird
Reply #41
This is a SICK build!  I really like how you are building your own suspension mods.  I curious as to the front torque arm connection.  I thought the front connection needed to allow for axle rotation up or down from side to side?  I guess you are not expecting any body lean in the corners, huh?
Keep up the great work.
The CP autox bird
Reply #42
That's pretty. I'm a little concerned about how it mounts to the crossmember. Is it going to bind? Dont most torque arms mount with a heim joint. But its freaking beautiful fab work.
The CP autox bird
Reply #43
Quote from: The Shredder;348417
You beat me to it.
I love this build. Not too many autocross t-bird/cougars. I'm paying close attention to the build.
The CP autox bird
Reply #44
The MM arm is attached with a bolt in single shear.  I didnt like that, and I didn't like the way the griggs arm attached either.  So, I tried something different.  It works for leaf springs, so why is this any different?  Its got the two bushings so that each one only has to take up half the movement.
This is an install I found of the MM torque arm that clearly shows the bolt in single shear
http://www.alanchavis.com/oldsite/mmtapb/mmtapb.htm
Griggs setup(scroll down a little - just a diagram)
http://www.griggsracing.com/installation/gr40.html
