Topic: The CP autox bird (Read 123625 times) previous topic - next topic
The CP autox bird
Reply #45
my goal is to not have a car that does this anymore!!
You get the idea.  Stock springs, bigger front swaybar, no rear swaybar, and strange shocks/struts, 295/35/17 hoosier tires
The CP autox bird
Reply #46
I just want a car that doesnt do this anymore!
This gives you an idea of what stock springs, strange shocks/struts, poly bushings, bigger front swaybar, no rear swaybar, and 295/35/17 Hoosier A6's do.
The CP autox bird
Reply #47
Quote from: fordguy545;348428
The MM arm is attached with a bolt in single shear.  I didnt like that, and I didn't like the way the griggs arm attached either.  So, I tried something different.  It works for leaf springs, so why is this any different?  Its got the two bushings so that each one only has to take up half the movement.
This is an install I found of the MM torque arm that clearly shows the bolt in single shear
http://www.alanchavis.com/oldsite/mmtapb/mmtapb.htm
Griggs setup(scroll down a little - just a diagram)
http://www.griggsracing.com/installation/gr40.html
I'd have to say that I like yours better.
The CP autox bird
Reply #48
knew this project was going too good.  Had some setbacks tonite.  I welded two of the three bars with inserts in them.  Tig'd them and turned out great, only I can only get one of the 4 rod ends back in, and I managed to get another STUCK in the insert and CAN't get the  thin back out :suicide:
The other setback is the set of caliper brackets I bought that I thought were for 03-04 cobra size rear brakes except for a straight axle.  Not even close to fitting :facepalm:
bought these
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=170582250213&viewitem=&sspagename=STRK%3AMEWNX%3AIT
The CP autox bird
Reply #49
Can you tap'em? Try heating up the other to unscrew the rod end.
The CP autox bird
Reply #50
I tried heating but it didnt do anything.  Problem is they are right and left hand 3/4" thread.  I have to find somebody with at least the left hand tap
The CP autox bird
Reply #51
I wish you were closer. We have a left hand set at the shop.
The CP autox bird
Reply #52
well, I pretty well destroyed the panhard bar trying to get that rod end out so I will have to make a new bar.  Never did get the rod end out since I was lifting myself off the ground while using a 4ft long cheater bar on it.  I will see if someone around here has the tap though.
The CP autox bird
Reply #53
Quote from: fordguy545;348436
  thats nuts, i think with enough speed and turn it just right it would end up on its roof lol
The CP autox bird
Reply #54
Quote from: fordguy545;348669
ouch. I always run a tap thru all inserts before I ship any rod out.
says GT in the auction. :punchballs:
sorry to hear about it man.
The CP autox bird
Reply #55
after a long time of digging and burning out seam sealer I ended up with shock towers that looked like this
Finished reinforcement
Also got taps for the inserts, and the correct axle brackets for the brakes.
The CP autox bird
Reply #56
Kind of ironic but i believe that orange tc was at CJ07... at the cruise-in. other than that the build is going amazing. Looks Top Notch.
The CP autox bird
Reply #57
I highly doubt the parts car was, but the burgundy one was at the 08 catjam.
The CP autox bird
Reply #58
Had to have been very close to it including the rust. lol. but sorry for the thread hi-jack car looks good.
The CP autox bird
Reply #59
Finally got the right brake brackets :thumbsup:
Got the Fuel tank mounts made(man was that a PITA to weld.  Broom handles helped push the sides back out to weld but still couldn't get a couple places right :shake: )
