Topic: The CP autox bird (Read 123539 times) previous topic - next topic
The CP autox bird
Reply #225
bigger pix here http://www.flickr.com/photos/38662362@N05/sets/72157626851364800/
Went to a detroit scca event on monday at the Pontiac Silverdome.  I was the only car in class and they made me run first heat.  The lot was terrible(gravel, breaking up asphalt, glass in places-most of that got swept up though, 1.5' tall weeds) and my new strut setup made it even worse(repaired bent spindle mounting tabs on bilstiens and reinforced).  The repaired struts actually made the car want to turn in and as soon as I even thought about turning the wheel, the back of the car was sliding, so I spent most of all of my runs trying to keep it behind me.  The rear tires are done, so I'm upgrading to the next size - 315/30/18.  There was a guy there with a turbo sky running 295/30/18 tires on 8" wide wheels, so thats a 2" narrower wheel than they are supposed to be on, and the 315's will only be an inch narrower so it shouldn't be too bad.
The CP autox bird
Reply #226
The second picture is AWESOME!
The CP autox bird
Reply #227
everything about this car is awesome.
83 Thunderbird Heritage - Right Hand Drive
95 Falcon GLi
The CP autox bird
Reply #228
Thanks for keeping me supplied in desktop background images...car looks awesome in action.
The CP autox bird
Reply #229
WOW!  The fastest Non-PRO driver/car out there.  Congratulations!
The CP autox bird
Reply #230
heres a few pics of my strut reconstruction.  Just took a couple pieces of 2" schedule 40 pipe and ground it out to fit over the strut.  I welded them around in a few spots, mainly to the original spindle mount tabs, then welded a couple pieces of flat stock on.
I also put on hawk dtc-60 brake pads all the way around and MAN what a difference!!  Thing stops on a dime(probably less than 75' from 60mph)
The CP autox bird
Reply #231
Awesome project!:cool:
The only schedule 40 I ever worked with was PVC so I was scratching my head for a moment!  :D
For all of those following this, just for fun, go back to page one and the first few posts.....it's come a loooong way!
tbirdregistry.com
26480
27373
The CP autox bird
Reply #232
Looking good. Should do the job I'd think.
What pads did you have on it?
The CP autox bird
Reply #233
Quote from: flylear45;361020
"I also put on hawk dtc-60 brake pads all the way around and MAN what a difference!! Thing stops on a dime(probably less than 75' from 60mph)"
LOL
1986 T-bird
347 stroker motor
185 AFR Heads
TrickFlow cam 224/232-542/563
Victor Jr. intake CNC ported
Quickfuel Holley 800 cfm
Hooker 1-3/4 long tubes
Custom built AOD
B&M 3000 stall
8.8 w/4.30 gears
UPR upper/lower control arms
Strange shocks/struts
26x10x15 M/T slicks
11.48@119.27
(coming soon Tremec 3550)
The Finished Product
The CP autox bird
Reply #234
Quote from: 347Thunder;361022
LOL
Right. What did he change FROM?
The CP autox bird
Reply #235
Freaking awesome project!  I am still stuck on the interior! Cant wait to get started on the chassis/engine.  Love threads like this....gives a guy lots of good ideas.
The CP autox bird
Reply #236
Quote from: flylear45;361024
They were unknown(probably stock).  They came with the brakes.  Mainly I upgraded hoping that they would have better braking while waiting for vacuum to rebuild.  Sometimes I wait for brakes and its a little unnerving since my burgundy car had no wait what so ever!
The CP autox bird
Reply #237
Welcome the newest member of the failed aux shaft club! On my third run at an autox today, it just sputtered and died. Tried changing the tps(since I still had one hanging there) and that didnt help. Tried a couple different tfi's when I got home-no luck. Pull distributor cap and cranked it, and gee it didnt move  So guess what I'm doing this week
The CP autox bird
Reply #238
Sorry to hear it, but you keep that bad ju-ju over there!!
*knock on wood*
The CP autox bird
Reply #239
So the timing belt is OK, but the Aux shaft is shot?  Or is it the old distributor gear stripping?
