Topic: The CP autox bird (Read 123530 times) previous topic - next topic
The CP autox bird
Reply #210
Love that pic! It's motivated me to get on the ball and start doing my body work and painting my car end of the month. I can't wait. :) My car will look like a distant (and slower) cousin to yours. lol (I've got similar wheels, but I'll be all black and with a cougar front end)
EDIT: and yeah, its my wallpaper right now too :)
'86 Turbo Thundercat (Cougarbird)
'02 TrailBlazer LT 4x4
'08 Chevy Cobalt
The CP autox bird
Reply #211
its also on my desktop wallpaper!!!
The CP autox bird
Reply #212
Quote from: flylear45;359475
What is it acting like down on power?
wastegate actuator broke off.
The CP autox bird
Reply #213
Quote from: fordguy545;359494
So you found the problem, or that's what it is acting like?
The CP autox bird
Reply #214
The CP autox bird
Reply #215
Fordguy545, pm sent
Very very nice ride and pic!!
86' T/C 4.6L DOHC
16' Chebby Cruze 1.4L Turbo
“Heavy Metal Mistress”
[/COLOR][/SIZE]
The CP autox bird
Reply #216
Quote from: flylear45;359501
That was the problem.  It actually broke the pin off the turbo elbow lever, so I modified a IHI actuator and put it on since its pin was on the actuator rod.
The CP autox bird
Reply #217
Great!
How's it running now, then? Feeling like it should?
The CP autox bird
Reply #218
well, its not running very good right now because I updated the firmware in the megasquirt so I could use tunerstudio and spent all afternoon trying to get it to run again.  When I finally did get it running, then I couldnt retune it because I didnt have my registration info for tunerstudio for VELive.  I will go back tonight to try driving it around to tune itself, IF it would quit raining.  Slicks FTL in rain
The CP autox bird
Reply #219
ok well the megasquirt has been fighting me since I updated that firmware, and finally messed around with the megasquirt enough times, I broke a pin off the processor:(  After that happened I had enough and robbed the bamafuel(MS1) out of my red car, and got it running on that this week, but the timing wasnt holding.  It would retard almost 40* on a free rev.  This had me scratching my head all last week, and finally dad helped me figure it out.  I had power on the start wire for the spout and couldnt figure out why.  I knew I had put a diode on that wire.  I hadn't thought about another wire backfeeding it.  Turns out I had the coil hot wire coming off the same terminal on the starter solenoid(since power to the coil is lost when the key is turned to start).  I ran that wire without even thinking about it messing with other stuff.  1 diode and it holds timing perfectly, but the ms1 won't control the timing at all.  If I set the program to ford tfi ignition, it wont even run, so I have all the ignition options turned off and am currently running it at 25* locked timing.
That must be working since I ran at an autox at toledo express airport and held FTD for 2 heats!  This car is pretty well balanced, but my rear swaybar is too stiff because its lifting the inside rear.  I only had a light mark where the front tire hit the fender so its setup relatively good already.  I will probably weld extensions on the swaybar and figure out how to attatch it farther forward, or find a smaller bar.
The CP autox bird
Reply #220
Should be easy to repair the pin on the MS2.  I just finished putting my MS2 together and testing it.  Might bug ya if I run into problems.
The CP autox bird
Reply #222
Shows you had the burgandy car; they need to update their database??
You should put your results in the autoX thread!
The CP autox bird
Reply #223
The CP autox bird
Reply #224
no, I forgot to change it when I preregistered.
Ok, I'll paste them in the other thread.
