Topic: The CP autox bird (Read 123565 times) previous topic - next topic
The CP autox bird
Reply #240
usually when you loose the distributor gear, you loose the aux shaft too.  I have a spare aux shaft, and will try to find a NEW gear, bronze or otherwise.
The CP autox bird
Reply #241
That sucks. Have fun getting all the shrapnel out of the oiling system. That s gets around FAST.
The CP autox bird
Reply #242
Welcome to the club!
The CP autox bird
Reply #243
well thats alot worse than mine is.  My gear is only half gone on the distributor.  one side is perfect, the other side is gone, hence why I think its my own doing.  Same on the countershaft.  Hopefully I will get it all apart tonight and see if the oil pump driveshaft is bent too, or what.  Also check the bearings while I'm at it and change the rear main(since I couldnt get the pan out without pulling the trans and flywheel-its leaking anyway)
The CP autox bird
Reply #244
mine happened because I used a new dist, and an old aux shaft.
The CP autox bird
Reply #245
Awesome build, with some great fabrication man!
Sorry if i may have missed, but what size rims and offset did you end up running?  I know you planned on stretchin the fenders, but i didnt see any pics of it, looks like you just rolled them??
The CP autox bird
Reply #246
Wheels are 18x10 with +20 offset I believe.  I couldnt get anybody to widen them, so I just rolled the fenders.  I can still get a 315 on the wheels, but only on the rear.  No clearance on the coilovers in the front with any wider than 295's.
Engine is getting new bearings tossed in it for now while I start building another engine-just a little ahead of schedule.
The CP autox bird
Reply #247
It lives again!  Although my plans for a new engine have been moved up in the schedule.
The CP autox bird
Reply #248
You may have already mentioned this, but what new powerplant do you have planned/scheduled?  Keep up the good work, the car is awesome.
The CP autox bird
Reply #249
another 2.3 or a 2.5.  Gotta weigh my options though.  Either of them will have good rods and pistons(crower rods,cp pistons) and maybe a set of honda oil squirters.  Did them on the engine in my red tbird and wasnt too hard.  I do know it will get a melling m127 oil pump.
The CP autox bird
Reply #250
Glad to hear you are keeping a 4cyl in there!
The CP autox bird
Reply #251
Would you like a spare block?
The CP autox bird
Reply #252
already have 3 spare engines
The CP autox bird
Reply #253
just happened across these pictures.  Don't know who took them, but there are some good shots of my car in there.  I ended up winning my class - results at the end
Rest of pictures
http://www.flickr.com/search/?q=nworscca#page=0
results
http://nworscca.com/attachments/results/2011/2011_e3_results.htm
index
http://nworscca.com/attachments/results/2011/2011_e3_index.htm
I just wish I knew how my dad ended up turning 2 seconds faster than I did - I think its mostly because he ran 3rd heat and I ran 1st heat(was hoping to be out of first heat going to this class:doh:)
The CP autox bird
Reply #254
This. Is. AWESOME.
