Topic: custom (cupholder) console installation (Read 7894 times) previous topic - next topic
Can a console be installed without this boxed in area?
I'm considering replacing my consolette, but man, I don't wanna lose my cupholders!:hick:
Quote from: sarjxxx;325062
I don't think it's worth changing the consolette over. The consolette looks better than a chopped full length console and serves all the same functions. I suppose you could cut off the front because there is good bracketry in the mid and rear of the console.
Yeah, I like the consolette, but it sucks that it moves if I move my seat forward(since its attached). So I thought of putting in a real console.
If you see in this pic, the cupholder comes all the way up to the end of the console. So I cannot move my seat forward without moving the cupholder, which I always have to unscrew from the floor.
I figured I could either cut the  boxed area off and fabricate a front piece for it, or what would be more interesting, leave it the way it is, and fabricate a seamless top piece that incorporates a set (perhaps not these) of cupholders into it. Probably from the ashtray forward cause I don't need or want that anyway.
time to do some cleaning.LOL. Yeah,keep the consolette if you want the cup holders.If you swap,you're not gaining much unless you plan on doing a floor shifter.
Quote from: vinnietbird;325093
Ummm.... yeah. definitely. You should see the passenger floorboard!
Yeah, I'm still not sure about keeping the mini console. The only reason I wanted the full console is b/c its stationary. If I could find a way to mount the consolette to the floor I would.:hick:
Seriously. I would.
If you are not converting to a floor shift, make an insert to with cup holders. Shouldn't be too hard at all.
Shiny Side Up!
Bill
what years came with the cup holders? I have been looking for a place to put one in mine and cant seem to find a good place
For most T-Birds the only cup holder option, is the driver's legs.
...and there was light!
You need these
I have a plan for cup holders for my console.News as it happens.....after the other friggin' cs on the Sport are done.
If you have the column-shifter full console, the pocket area holds two pop cans nicely. However, if you put a 44oz speedway cup full of "code red mountain dew" in there, you will have a red floormat on the first corner. Ask me how I know.
CoogarXR : 1985 Cougar XR-7
Quote from: CoogarXR;325210
how do you know? :flip:  I couldnt resist
You need to take that back, code red is not moutain dew.
I kinda like this color red better than my stained gray carpet
Quote from: ProTouring442;325167
Shiny Side Up!
Bill
Yes I think this is a better idea if you want cupholders large enough to hold your big gulps. You can easily fabricate a plate to fit on the top of the front console plate. You could do this with thin wood with two large cup size holes and cover this in vinyl. I would even go a step further and cut out the bottom of the original console trimplate so you would have extra depth down to the floor tunnel, that way you do not spill your Code Red or whatever.
