Topic: 5.0L upper plenum plate (Read 2102 times) previous topic - next topic
Looking for another 5.0L upper plenum plate. Let me know which one you have. Pics would be nice.
88 Thunderbird 5.0L
[/SIZE]
Ive got several, Ill try to get some pics.  You can sand the paint off whatever else you want on the painted black one.
Mike
Ttt
Mike
if you have another extra i could use one. pm price with shipping. thanks
Ill grab some more at the yard next time.  If Tyler doesnt want one Ill let you know.
Mike
thanks, will both fit or each diffrent? mines the black one.
I've got a few,but they are all in the process of being polished.They'll go for about $35-$40 each depending on which one a person wants.
Quote from: birdman7;323394
They both fit.
Mike
Quote from: vinnietbird;323395
You got any with just 2 holes?
Quote from: daminc;323471
For the Explorer upper? Here's the easy trick I did. I just cut the heads off two screws and glued them in the extra holes on the plate. You can't tell when the plate is installed that only two screws are holding it on ;)
what's wrong with just putting a plate that has 2 holes back on.
I made my own from aluminum sheet.polished,smooth,and only two holes.Took about ten minutes to cut and drill the holes,then about an hour to smooth and polish it.FREE as well.
I was thinking about re-machining a plate anyway, so If I had an explorer 2 hole plate, it's not really going to matter. Anyone got a 2 hole'r they want to give a new home
Quote from: daminc;323484
It limits your "style" selection;) If you're making your own plate you can do what ever you want though:D
I'll sell this one for $13 shipped  to the lower 48 of the  USA
