Topic: 5.0L upper plenum plate (Read 2100 times) previous topic - next topic
send that bad boy my way! save me from painting it red! thanks, dwight
Do you need more?
All my explorer plates have 4 holes, just have a bit of paint or sealant in the unused ones. Not sure there is such a thing as a two hole explorer plate.
87 Thunderbird 5.0
Engine: 97 p-code explorer block, heads, and intake; 88 HO cam, 1.7 RR's, A9P, Kenne Bell 2.1 Flow/Blow 8psi, 42lb injectors, LMAF, 75mm TB, Tuned by Don Lasota
Trans: 02 Stang 4r70w with Baumann TCS
Suspension: Front: 03-04 cobra springs and struts, TC rack. Rear: CHE arms, ChuckW shock mounts, Bullitt springs and shocks
5 bolt with 95 mustang front and mark vii rear.
TC 3.73 L/S rear
03-04 SVT Cobra 17x9's with 275/40r17's.
My Explorer plate has two holes. All of my Explorer plates have only had two holes. There are two fake holes (little indentions),but only two actual holes for the fasteners.
