Topic: Imported Iron (Read 7419 times) previous topic - next topic
Imported Iron
Being original is why I beefed up my V-6 instead of putting in the V-8. When I did it a few years ago, everyone thought I was nuts.
Imported Iron
Sounds like another "all talk, but nothing gets done" thread. Who was that tool that said he was going to put in a Supra motor, because he wanted better gas mileage? He only posts when he has a crazy idea or to ask something that's been asked a million times.
1979 Ford Fairmont
[/B]
Imported Iron
See, it's not so  much a "Ford in a Ford" issue for me, because if I could get my hands on a cheap LSx engine/tranny it'd be in the T-Bird before you could blink (assuming you blink really slowly). No, the reason I said I wasn't for the idea was that it seems more of a make work for the sake of making work project. Virtually everything would have to be custom made, and this takes time and money for something that would provide almost zero return on investment, both in the car's value and in drivability improvements (over the Ford modular). Like I said, all the parts are out there to swap in a DOHC Ford modular engine. Most of these parts can be bought used (1996-2004 Mustang K-member, headers, etc). There is a vast aftermarket for the Ford modular, and these are very durable engines (I've seen many SOHC versions with over a million kilometers on them). And then there's that T45 option (to my knowledge that Toyota V8 was never bolted to a manual transmission)...
Just driving an 80's Cougar is different. Installing a Ford modular into one would be even more different (I've seen two DOHC modular 'Birds, but no Cougs). Chances are you'd have the only one in your state. Why make unneccesary work and expense for yourself just to be even more different?
Imported Iron
Quote from: Thunder Chicken;319981
Agreed...A modular would be saweet.
I'm not totally biased against off-brand engines in a Ford...I just prefer Ford cars with Ford engines, GM cars with GM engines, etc.
Here is a perfect example of a GM LS series engine being put to good use: http://www.youtube.com/watch?v=ugoBL3y0YbU  That one has a 5.3 truck motor with a turbo!
Imported Iron
I'd say you have a well enough reason (200k on an engine) to do it. Seems like it could be a good amount of work to get that up and going but to each their own. It you can set everything up I say do it. If you wanna do it to be a little more different....well look at what we drive
Imported Iron
ok now the modular motor has my attention. How did i not know there was a carb manifold for them????????????!!!!!!!
P71 'Vics are everywhere.
and my gears keep grinding,
either way Ill be the last one to put any Chebbie parts on anything,
i dont care if its a throttle return spring for my lawn mower,
Ill take parts from anywhere but Government Motors.
The 4.6/5.4 family has never seen variable valve timing though, Right???
Current-
87 Cougar
88 Crown Vic LTD
84 Yamaha Xt600
previous cars -
1990 Dodge Daytona -
1990 Geo Prizm -
1987 Honda Accord - 140mph wonder? Rally ready..... K.I.A. at WOT due to massive head failure. Still had the best paint-job EVER...
1998 Suzuki Sidekick 4D -
1969 Falcon Futura w/ Sports Coupe option (now go try and find that? And if you do tell me where it is!!)
The Cougar will never be for sale, Only up for trade on a 68,69 Falcon 2D.
Imported Iron
The 2005 and newer 3-valve has variable cam timing IIRC...
Imported Iron
5.4, and 4.6 3 valve motors have variable cam timing. which gets rid of the egr system believe it or not.
Imported Iron
Quote from: daddybair7;319707
my stepmom has an 09 tundra v6 even though the engine is peppy it still has its issues with the drive line she sets the cruse and even on flat road it jumps into passing gear way to much and with only  15k on it the vale train rattles bad. she takes it to the dealership for all services and they say their is nothing wrong i went with her the last time watched them check it out all they did was change the oil didn't even try to check on the issues she was having with it. i ask the service manager y they didnt look into it he said they were to busy with the accleration problems to deal with it right now. I am in the process of dealing with anouther dealership to help her out.
Just to let everyone know the rattling in the engine was caused by a bad timing chain guide. The cruse control issue was fixed by reseting the computer just an update
Imported Iron
Reply #39
Hmm, good info. I didnt even think about the chain guides but it makes far more sense than valve adjustments. Its been my experience that most OHC chain guides are over tensioned and under oiled for the pressure. Just my thought on it.
Current-
87 Cougar
88 Crown Vic LTD
84 Yamaha Xt600
previous cars -
1990 Geo Prizm -
Imported Iron
Reply #40
Yea im glad they fixed it for her but for the size of the truck it still gets py fuel milage. the best i've seen her get is 18 highway 15 avg. Hell my 5.4 f150 gets that. The 93 yoto truck i use to own got 25 highway maybe it will improve since they reset the computer.
