Topic: project spoolup (Read 5448 times) previous topic - next topic
project spoolup
So, my tbird seemed like its been getting less and less low end boost so I figured its time to change that.  Guys on turboford thought that the way I had my collector designed, it would be a little detrimental to getting this big holset HX35 spooled up.  My main concern was the $50 ebay wastegate I was using not to mention it would no longer go down to 12psi.  Lowest it would go was 22psi :rofl:  So the collector is getting remade, and twin tial 38mm Vband wastegates.  I think I will also put the new engine in while I'm at it.  New engine should be good to 8000+ rpm
What I started with
New tial's
Proposed location for the front wastegate
Took the easy way out to get the turbo and manifold out - took head off :facepalm:
Hmm, dont think it was sealing anymore :huh:
Header progress
project spoolup
Well, This is all progressing pretty smoothly!  Glad too because its gotta be back together by the end of the month to have about a week of break in time before going racing!
project spoolup
holy bundle of snakes, batman!
project spoolup
You gonna make the wastegates dump out of stacks coming out of the hood?
project spoolup
nope, they will end up back in the downpipe
This will probably be the only twin scroll, twin wastegate WITH A/C in existence, ROFL
project spoolup
Every time I see a post like this, I think "man I wish I could weld". Then I think "man I wish I had a place to weld", then I think "man, I wish I even had something worth welding"... In other words I am jealous and envious of your skills and your nice shiney stuff, heh.
CoogarXR : 1985 Cougar XR-7
project spoolup
That stuff hurts my mind.
project spoolup
:rollin::rollin:
project spoolup
I think you need a bigger [SIZE="7"]TURBO COUPE[/SIZE] badge on the trunk lid;)
project spoolup
That looks significantly better than your last collector.  It will be interesting to see how it works.
__________________
Twin '85 TCs
White/ Grey 2-tone
project spoolup
Holy boosted Bird shiznit Batman! That's awesome!
Out of curiosity, are you going to build a brace or bracket of sorts to help hold all that up, or is all to be "hung" off of the exhaust bolts/studs?
Forgive my ignorance, just can't imagine that being a featherweight setup there...:D
project spoolup
Who said anything about featherweight? Rofl. Two ton Autocross car.
You're gonna throw me out the passenger window this year huh?
project spoolup
Quote from: bhazard;312750
You bet!
As for the brace, I had one going to the block before, but it was absolutely impossible to get in or out with the head on, so maybe I can move it to a motormount bolt or something so it wont get caught on stuff.
project spoolup
Looking good man, keep up the updates.
