Topic: project spoolup (Read 5484 times) previous topic - next topic
project spoolup
its just high temp header paint.  VHT flameproof or something like that.  The BBQ paint I used on the turbine housing actually held up fairly well and the ceramic coating I had put on the header originally didnt hold up very well anyway so it'll look nice for a little while, lol.
project spoolup
You didn't have luck with the ceramic? That's interesting.
I'm going to be yanking my hotside to paint and wrap it soon, and am looking for options. I've used the BBQ black in the past with decent results, also, so maybe I'll just stay with that.
One other question, Fordguy. I like the way you modified your AC lines to route the away from heat as much as possible. Did you just go to a local hydraulic hose shop to get those made up?
On an aside note, my neighbor got one of those 42mm wastegates for his 2.3 BMW, and it was a POS also. It never sealed and leaked right out of the box.
Those Tials are gonna be great, and having two is really the way to go on a split scroll. Good engineering, bud!
project spoolup
well, the ceramic was good till my distributor loosened and turned 25 degrees retarded at autox.  All the header stuff got so hot, the ceramic flaked off and melted the a/c drain off the firewall.  The a/c hose was made up at a local autoparts store.  Although I have yet to be able to get the a/c system to be completely sealed.  All the refridgerant keeps leaking out.
project spoolup
Thanks for the info. Good luck this year with it!
project spoolup
hmm, something missing :sad:
New engine getting parts
Ready to go in!
New engine in
project spoolup
That block looks really nice. You didnt paint the trans though??? ha
You gonna need an underdrive so you dont spin your accessories at 10000 rpm? That'd be some cold AC.
project spoolup
Why's the trans need to be painted brad??  Ya cant see it!!  And the a/c compressor will never see that rpm because it will never be on while under that kind of rpm.  Though the p/s and alt may, lol.
Hmm, looks like I actually got something done tonight!
Not going to be too much longer before its ready to start, but I still have to sort out attatching the lines to the wastegates and the final routing of the turbo oil drainback.
project spoolup
I was kiddin bout the paint.
The overspun power steering will be nice for autox. The overspun alt will help charge the flux capacitor disguised as a holset.
project spoolup
Got this running friday, and its making boost much better!  5psi by 2100rpm so once I get it all ironed out, it should be able to make the full 25+psi by 3000rpm!
project spoolup
Reply #39
Awesome...gonna dyno it?
We'll need a video too....puhlease!?
:D:bowdown:
project spoolup
Reply #40
Great news. Keep us posted!
