Topic: Back in an '80 XR-7 (Read 28534 times) previous topic - next topic
Back in an '80 XR-7
Reply #105
Quote from: Chuck W;312771
Now, if I pull the carpet up, I might as well work on the through-the-floor SFCs...
the "while im in here"s get me every time!
youre still hiding that material back from when i did mine, im sure.
Back in an '80 XR-7
Reply #106
Quote from: gumby;312775
Well, this is one of those things that makes sense to avoid having to pull it all out twice.
Yup, the material is still in the garage.  It *almost* went to Joe (the guy with my old car)...but he's not getting it now. ;)  I could really use that NOS pass side mirror I included with the sale though :(
Back in an '80 XR-7
Reply #107
Well, I was able to sneak in a little more time on this on Sat between welding motor mounts and yard work.  I was also able to roll the windows down to help air it out a bit.  Not quite as bad as it was a couple days ago.
I still need to try and find the front bumper lights, as mine are shattered, but I spent some time trying to sort out why the right side turn signal will not "blink".  Left side works just fine, and the right side blinks with the hazards.  Perhaps the multi-switch is bad.  Both circuits use the same blinker module, so I'm not quite sure yet.
Also I evidently have a short in the horn circuit.  Blows the fuse as soon as it's put in.
The car has an odd lean to it, most likely in the springs.  So....I broke down today and bought a set of C-Kit fronts for it, and I have a set of rear springs in the garage I can use.  The front was WAY too hight anyway, and the odd lean was causing the car to track funny while driving.  I can kind of sort it out, and make sure it's aligned right now.  Not planning on doing much more with the susp at this point right now.
Back in an '80 XR-7
Reply #108
Any updates or new ideas?
There is going to be a SHO powered 4 eye Mustang very soon out in CO. Boosted too.
Back in an '80 XR-7
Reply #109
Funny, I was just going to update a bit.
Been busy as hell with everything else, but took some time to mess with the odd-ride height issues.
I FINALLY was able to get my hands on a set of Motorsport C Kit springs for the front.
Here's how they compare to the stockers.
This pic is after I swapped the fronts (did the rears later), so there's a bit of rake still in it, but not so much now.
I also installed an old set of KYB shocks in the back I had in the garage as what was on there was completely shot.
Do you have a link or anything to the Mustang getting the SHO?
Back in an '80 XR-7
Reply #110
That''s much better, now you can swap a better pic in your sig. In fact...... this one is almost the same as your old one. except there's a bush or tree missing next to the house next door. lol
Back in an '80 XR-7
Reply #111
http://www.shoforum.com/showthread.php?t=107674
Cool guy. I picked up his boosted '90 SHO last Wednesday. It will be a quality car when its finished.
Back in an '80 XR-7
Reply #112
Quote from: Chuck W;317697
Wow, what a difference! Between the wheels and the lowering job, it really gets rid of the too-big-a-car-on-too-small-a-chassis syndrome these car suffer from.
Shiny Side Up!
Bill
Back in an '80 XR-7
Reply #113
Quote from: ProTouring442;317741
Yeah, it does help.  What will really help will be when I can get the SVO rear brakes/axles on it to widen the rear track out a bit like on the old car and get some real wheels/tires under it.
The C-Kits are really nice to install.  Once you get the old springs popped out (I don't use a compressor to remove them), the C-Kits just slide in place with the arm swung down, then just jack up and attach spindle, done.
Also, as a side note for folks dealing with cleaning out the spring pockets after removing springs that have been corroding in place for a couple decades, an air chisel works wonders.  Only takes a few minutes to knock all the  out of the way.
Back in an '80 XR-7
Reply #114
Hmmm! Project SHOe Box on a shoe string budget. I like it! :)
The 'e' is for enhanced. :D
Keep it up, Chuck.
Back in an '80 XR-7
Reply #115
I had a Cougar almost jump off the jackstands one time when the spring compressor i was using broke.  It was pretty impressive how high that car jumped.
And what's wrong with snowflakes?  I think they look good when done with a monotone themed car.
:pics-stfu:
 Project Thread with pics
Back in an '80 XR-7
Reply #116
Quote from: blu84302;317946
I have removed dozens of sets of stock front springs w/o a spring compressor.  Makes more noise than anything, but obviously don't stick your face (or anything else for that matter) in the way of the spring.
What's wrong with the snowflakes?  3 things.
1. Only 16"
2. Only 4-lug
3. They're snowflakes.
Back in an '80 XR-7
Reply #117
What 5-luggers are you gonna run?
Back in an '80 XR-7
Reply #118
Quote from: Ether947;317970
Haven't fully settled on it yet.  I was wanting some mesh-type, which would fit the vintage, but can't find any 17" outside of having them custom made, which is not an option, or finding them too narrow.
Fallbacks include 96-97 Cobras (with the painted inserts), or perhaps black Bullitts.  94-95 Cobras are a possibility too as they looked good on the old car.
Back in an '80 XR-7
Reply #119
*sigh*
Well, I was moving the cars around last night (drove the Tbird the past couple days and needed to get it back in the garage), and was pulling the XR-7 back up into the drive and felt a *pop* when I went to stop.  Rear brake hose went.  Peed all over the drive. Nice.
Just going to toss a stock replacement piece on there for right now.  Not going to fuss with a braided line until I sort out what I'm ultimately doing with the rear susp.
