Topic: Biggest reliability issues with T-bird? (Read 3257 times) previous topic - next topic
I'm picking up a 88 T-bird sport coupe in 5 of 10 condition tomorrow with 230,000 miles and still running strong.
5.0 is sludgy and leaking due to v/c leak, cracked windshield, tail lights are not working (where would I look to repair this, fuse? faulty wiring?
Drivers window is off the track and comes up all crooked (whats the cause behind this?)
My plans are to pressure wash the hell out of the car, outside, engine bay and undercarriage, New battery and all new tune up
Then HO conversion and nice exhaust system for my daily 60 mile round trip commute.
Electrically, what are the biggest gremlins in these cars and what are the fixes?
window's an easy fix. prolly just the epoxy's loose in the "U" that holds the glass.
if both taillights aren't working, more than likely a fuse. no biggie. the ignition switch module thing would be well worth replacing now, as they have issues. cheap fix.
The heater cores usually go to  as well.I'd swap it with a Ford part while the weather is nice or you'll end up needing to do it in the dead of winter.
Only major issues I've ever had with these cars are broken front springs and the POS 3.8L engine, but you don't have to worry about that.
1988 Thunderbird
306 HO w/ A9P processor
AOD w/ Transgo Reprogrammer
245/50/16 Tires on Snowflakes
Check the wiring at the BOO (brake on/off) switch, which is located about halfway up the brake pedal.
Those wires flex right at the connector and separate.
think mustang, minus about 75hp, and then make it better.
Quote from: cougarcragar;265123
Yep I've had that happen, twice. I finally just replaced the wires. It was a PITA job too as it's a tight space to be in with a soldering iron :hick:
The only thing I've had go wrong with my 88 has been the heater core going out. The rest of the stuff, even the engine, was just an upgrade. The old 5.0 SO would still be ticking away right now if I didn't want more power :burnout:
wiring diagrams located in Electrical tech up to in a sticky called 87EVTM
In honest opinion,
my bigges hassel with these cars are brakes up front.  A shakey steering column while braking tells you either
a caliper hose is eaten up inside not allowing fluid to bleed back when you get off the brake,,keeping presure on the inner pad.
this creates heat, cooks wheel bearing greese, warps rotors and causes calipers to stick.
Heater core is pretty much a given although there is an easy way out.
Cougar Cragar you were correct. The connection at the BOO switch was broken. Fixed! Thank you
Quote from: quick50stng;265048
Beware.  I've always been warned about PW under the hood.  Been told it could RUIN some electronics etc.
It can be done just have to cover the distributor and top electronics up with plasticand concentrate the water on the bay area and block and try avoiding the top side.
Quote from: ~AC;265447
Expect the body color to come off too. After power washing around the lower engine bay, all I had left was "gray". Then it got sanded and repainted but that shouldn't be any problem.
1988 Thunderbird Sport
Quote from: thunderjet302;265351
Man I know exactly what you're sayin. I replaced the whole switch and wires - what a PITA X2. No room at all. :mad:
FOXLESS!!
1994 Lincoln Mark VIII
Well im about to hop on that wagon. I got the HO cam today along with a set of GT40 heads
Will an HO cam work with SO firing order?  If I'm reading my chilton's correctly, they're different orders.
