Topic: Biggest reliability issues with T-bird? (Read 3251 times) previous topic - next topic
No they are different firing order. I'm using a 91 mark 7 ecm
Quote from: Grumbles;270152
Will an HO cam work with SO firing order?  If I'm reading my chilton's correctly, they're different orders.
If you install the H.O cam,you'll need to install the H.O computer,19# injectors,and wire it like a 351W (plug wires).it would really help to upgrade the exhaust and intake at that time as well.
if your going to powerwash an old car that your rating 5 of 10 be ready fof a big mess :hick: if you going to do it in the street i hope theres a drin near by. or niegbors are going to freak lol
these are good very reliable cars especially in the 5.0s
Years and years of leakage left the underside of the vehicle a nasty hazardous mess. I bought a pump sprayer and purple power and took the car to the local car wash equipped with jack and jack stands. Degreased the undercarriage and put $6 worth of car washes to it. World of difference now. I have most of the leaks fixed minus the rear main seal. I haven't decided whether to find another short block to put my GT40 heads on or just build the top end till she blows up.
Going carbed, no computer necessary.  A little confused though, if the timing is different, wouldn't the crank have to be different too?
Camshaft events do not effect the crankshaft.
I guess what I mean is, if there is a timing change, wouldn't that then mean that the pistons are in a different position?
No, because in going to HO, the cam itself is changed, but the timing isn't directly affected by the bigger cam, just the firing order is different. Seems as if logic would make this impossible, but it is possible.
The cranks between HO and SO are identical.
On a related note, you can do what's sometimes called a "mid HO" conversion, using the HO upper/lower throttle body, etc...
But, if you are going to use the 19# injectors, you MUST ALSO use the HO cam and an HO EEC...those three components have to be used together!! ;)
I wonder if my crane cam is SO or Ho order.  Cant find out, company closed :[
well if you put the engine at top dead center. Pull the #3 plug. Rotate the engine manually at the crank. If the next firing cylinder is #3 a burst of air will push past your finger. That is a 351w/302H0 firing order. If air didn't push past then the next cylinder to fire was #5 standard 302 order
I have pressure washed plenty of vehicles. I start the engine when it is cold , leave it running ( with the emergency brake on) and have at it. I stay away from a direct spray at electronic stuff. If the engine dies, I dry out the inside of the distributor cap and re-start it and continue.  That's is how I do it but I am not advising anyone to do it.;)t
83 T-Bird 460
83 T-Bird Heritage 5.0
84 T-Bird 5.0
87 T-Bird Turbo Coupe
88 Bronco II Drag truck 302
95 Mustang GT auto
2004 F-350 CC Dually V-10
