Poll
Which should I get?
Total Members Voted: 27
Topic: E7's rock AOD's SUCK (Read 7528 times) previous topic - next topic
Got the idle and vaccum lines done, threw in sparkplugs and the car sounds awesome. Threw alittle more tranny fluid and went out for a drive :burnout: .
Spun the tire almost all the way to 40 mph. Now that the cars running right, I decided to go to jiffy lube to get saftey and emissions done, and I have no second gear. I have third, and overdrive but no 2nd...
I didn't notice that it was nuetral revving because I let off at the 2nd gear shift and slowed back down and parked it :hick:.
My father in law has given up on the car and wants it gone this weekend. I have been looking at a couple of cars.
87 XR7 black
Digital dash, turbo coupe interior and all the good stuff. But its in bad shape, needs a steering colum and exhaust and body is in rough shape. Needs exhaust. $300. If I got the car, I would gut the interior, tranny and axle, and throw it in my current car.
White 87 t-bird LX
The other is a 87 thunderbird, 87 5.0. I'm assuming base model. Runs fine and looks good, but has bad power steering and bad track on the passenger window. If I got that one it would have the new motor, and shouldn't need any other major work. The power steering I would swap out from my existing car, or junk yard and get a new rack. The exhaust is supposed to be good, and should only need 2 tires.
Overall its pretty much six's.
The car I have now is in decent shape, but is a light green, non-factory color. It needs a new hood and possible front clip, and I'll never find one the right color. I would like the body more of the bird, but the spiffy parts of the XR7 would be more fun...
Now back to work after all 3 hours I've had off today...
I've got an 87 turbo coupe for sale. You did say you like the looks of the birds! :)
mass is alittle bit of a walk for me. If you were down the street I'd look...
Just find another AOD. They came in so many cars. If you where closer I know a guy that has some SC AODs. that would be a good swap.
I say Cougar.
AOD's are hard to find, knowing they work at a junk yard, I'm looking at $400+ for a tested good one, with a 30 day warrenty/exchange. Unfortunately, time is a factor...
yeah but this one is worth it.......plus, if you for some reason you didnt like that one theres a very, very nice 83 turbo coupe worth looking at very close by as well. i wish i could have them both.
~John~
I like cougars, but the tbird sounds like its more solid shape. I vote tbird.
Mike
What do call "rough shape" for that cougar body description?
I'm thinking that it's worse than mine. But everybody has a different opinion about that.
Sounds like the car you have is as good as the ones you're looking at...
As far as the title of this thread, you have it backwards...
AOD's Rock, E7s SUCK... At least if you ever rode in my car that's what you'd think...
Wow 400 for an aod? i can grab one up here for 125 bucks....with a 30 day warranty..... cougar all the way, but work wise......t-bird, sounds like it in better shape..
[/IMG]
Just enjoyin the ride!!!!
Quote from: Haystack;242824
come to ri
ill sell you a AOD for as much as you can give me
Quote from: TurboCoupe50;242869
I looooooove my AOD. Between the shift kit itself and going ahead me maaaaaybe boring one or two of the holes just a tiny bit bigger than I was told *cough*OD->3rd*cough*:D  the thing is so responsive you'd never know it was 21 years old....
Yup.
You have a project car already from what it sounds like.  It also sounds like you want something in better shape than what you currently have.
Save some money and be patient until something better comes along.
I had AOD issues some time back (before the 5 speed swap).I pulled the valve body,and one at a time,I p[ulled each valve out,super cleaned,and re-installed until I did them all,re-installed the valve body,and the tranny worked like new.I found that a little crud can mess one up.I don't know if it's your problem,but it worked for me.You have to do that work in sanitary conditions.
Quote from: V8Demon;243151
Yup.
I agree. Patience is the key factor. I've been working on mine for two years. When you get in a hurry, you end up with more of the same, problems, throwing money at a temporary fix. When, if you had waited, you could've had a nice ride that works well.I'd like to have had my car done a long time ago,but I really watch what I spend, and build one piece at a time, trying to do the most important work first.That's why I'm FINALLY getting ready for paint. I kept getting postponed due to upgrading the mechanicals of the car (engine,tranny,suspension). If you look hard, you can find a tranny cheaper than another car.Patience....Patience....Patience. Good luck with whatever direction you go with it.
