Topic: the cougar is DONE!!!!.... HO/E303/MAS/T5 conversion complete. Drive Video added (Read 14567 times) previous topic - next topic
Reply #45
Vinnie- hows the low end with that e cam??
Reply #46
Quote from: kitzdnm;227765
Here it is.
Hey isnt that the scan I posted awhile ago
Reply #47
the moss pattern wont download the conversion filter.
is it something that can be posted?--irv
Reply #48
Quote from: 1WLD BRD;227779
It might be,had it for a while.
Reply #49
Don't think you'll have any problems with the e-cam but did you turn the engine over by hand a few reveloutions to make sure she's not contacting??????
O on a side note,lol,when you install the maf wires make sure to leave them about a foot or so longer than needs be just incase you ever want to install a supercharger as it relocates the maf to inside the fender and i ended up having to lengthen mine which kinda sucked.
Reply #50
SHE IS ALIVE!!!!!!!!!!!!!!!!
yes I turned it by hand first, lol, you should know I know what Im doing by now Chris...  hahaha...  I left some extra, but not a foot...  if anything It will probably get a Holset next. :evilgrin:
Reply #51
gear drive!
Reply #52
Just double checkin man,i know you and your luck with 5.0L's LOL.
I'll have to wait till i get home to hear it(at work)you take her for a rip yet???????
You know i was thinking about it,did you change the fuel pump out????
Also 19lbers are a little weak for that combo unless you up the pressure with an apfr,24's sound about right now.
Reply #53
Way to go Ron!!  Sounds better at start-up than mine did!!! oh yea... it was ALL fresh...lol
Reply #54
Welcome to my world !!!!!
Reply #55
I like it ,another e303 running on flat tops.Nice job.
Reply #56
Oh,the low end is pretty good from a dead stop.The car gets a little rubber in all the gears.I do believe the H.O cam was a little better on the low end though.But when you hit the mid range,awesome.The car LOVES the higher rpms....a LOT.
Reply #57
Wait to you put the t5 in there is no low rpm .
Reply #58
Quote from: vinnietbird;227845
Thanks guys...
Vinnie....  I like your world...  LOL.
yea she moves out REALLY nice now...:burnout:  I will have it at the track tomorrow night to see what she will pull.:evilgrin: Looking for a mid to low 14....
Yeah Chris I think I will upgrade to a set of 24's and a 155lph pump next, then a set of gears....  THEN the T5
and yes, Gear drive....  Love 'em
Reply #59
I think 13's is possible,what gear do you have?
