Topic: the cougar is DONE!!!!.... HO/E303/MAS/T5 conversion complete. Drive Video added (Read 14532 times) previous topic - next topic
Reply #90
here is a quick clip of me running through the gears:
ENJOY...
Reply #91
Nice !!! How fast were going when you hit 5th?
Reply #92
according to the speedo 100mph....  but I know the speedo is out as I am using the AOD gear in it for now, till I can get the proper one....
Reply #93
before you buy one,let me know exactly which one you need.I believe mine needs the 20 tooth gear,and that leaves me a few extras that I bought and can't use.When you figure it out,shoot me your address and I'll hook you up.
Reply #94
I need the yellow one for a T5....  for now, getting gears soon too...  just dont know which ratio I want yet...
Reply #95
I have the 19 tooth ready for my 3.27s
Reply #96
Its been a while but you have to look inside your t-5 and see what color your drive gear is. Some are 7 tooth and some are 8 tooth if I'm remembering correctly.
Reply #97
lets see some new times :evilgrin:
Reply #98
Actually,I have three white gears and they all have different teeth.You need a tooth count.
Reply #99
Quote from: Bob;233130
There are some buzzing around with 6 tooth drive gears too...but I believe those are only in 4-cyl cases.
Late 89-93 all had 8 tooth speedo drive gears. Part #' starting with  F0ZR and FZZR should have 8 tooth drive gears.
Part #'s starting with E3ZR through E6ZR should all be equipped with the 7 tooth drive gear...trans tag SHOULD be on the left side of the case...unless it was removed for some reason.
Good luck,
Don
Reply #100
Nice work on all the swap items. Car sounds good in the videos. Now we just need pictures of those long black marks by your driveway :D
Reply #101
Nice work on the trans swap! It looks like we've got a number of people going 5 speed now. And the car does sound good, you can tell it has an e cam. :D
Matt
Reply #102
Sounds good and nice pioneer cd player and don't tell me that car is doen i know you got more plans for it.
Reply #103
yeah I got lots more in store for it.... just waiting to get back to work....
I just got a set of meats for the next time at the track....:
I have a race booked at Sparta in 2 weeks against an '01 Bullitt, a '78 Mustang II with a 5.0L, and a 5.0L HO Fairmont, so I need some traction...
