Topic: Bought a modified '88 Turbo Coupe (Read 13548 times) previous topic - next topic
Reply #75
Quote from: cougar86_89;224635
No one complains about 5 lug swaps...
Cause 4 lug sucks!
Reply #76
does that car have the stinger header on it?  cause it looks like stingers IC piping.  I have my car torn apart right now doing the hx35 with a custom header and ported everything.  Also got a boport 1.9 cam in the new head too.  Unfortunately I will be running it off the stock computer and injectors for catjam because my bamafuel(megasquirt) setup still hasnt come.  It would be interesting to compare how much different our cars are in drivability, lol
Reply #77
Quote from: SLEEPER T-BIRD 87;224801
Cause 4 lug sucks!
And People can say the same thing about 2.3Ts
Reply #78
Quote from: cougar86_89;225034
:flip:
:birdsmily:
Reply #79
Sure can same for the block splitting 5 liters
Reply #80
Quote from: turbo88;224376
Putting a 5.0L in a turbo coupe is like moving sideways. You just added 200 pounds in the front end of your car and gained no substantial power.
Bull shiznit!!!
A carbed, iron headed 5.0 with cast exhaust and intake manifolds weighs approx 470 lbs(per Ford)... A fully dressed 2.3T in the neighborhood of 380... Bout all you can get rid of on the 2.3 is the exhaust manifold... While we 5.0 guys can run aluminum heads intake and tube headers(and I do)... So in reality there is maybe 50 lbs difference... Plus IF one wants to run a automatic(again I do), a 5.0 is the only way to go(OK I gotta give you a weight advantage with the T-5 now maybe 100lbs)... Yeah you can run a C4 behind the 2.3, but doesn't do anything for a good gear(3.73-4.56)on the highway...
Reply #81
Quote from: SLEEPER T-BIRD 87;225101
Im not on either side here. I love my 5.0 but I cant judge a 2.3T cause the only one i drove was on its last leg and an auto. All Im saying is no matter what anyone says it always ends up the same, they do what they want. I want the 2.3 to stay in the car on this one but if RJ does swap it then atleast it will be a good swap and the car will still live on. It isnt like things can never go back to 2.3
Reply #82
my dad had a stock one with a 5 speed
when the boost came in that thing took off like a freight train.
i mean it gave my 351 mustang a run for its money
Reply #83
Torque first!
1987 TC
Reply #84
Quote from: TurboCoupe50;225108
no doubt that on a scale there is not much actual difference in total weight, but the weight of a 2.3T is placed better(down and back). still not enough to justify a 200lbs claim, im just sayin ;)
and FWIW, there are aluminum head options and bell housing adapter plates available for the 2.3T as well.
any results from the track yet?
Reply #85
Quote from: daboss351;225114
yeah WHEN boost finally comes on, they move out OK.  mine has around 300hp, (going by what everybody that plays with these 2.3's has told me) and it is a dog off the line.  I got beat by an old mini cooper til the boost finally kicked in.  and yes I know you gotta abuse the clutch to leave hard.  sorry I cant afford to change clutches all the time, no revving and dumping for me.  this thing I rev it up to 3500, and dump the clutch and the thing bogs and barely spins til the boost finally kicks in.  kinda embarassing. LOL.  I miss takeing off nice and easy and sliding sideways at 40kms/h in the Capri.
Time to start aquiring some swap parts.  :flip: :toilet: to the 2.3L
nah, havent hit the track yet.  waiting for my EI to kick in so I can afford to go.
Reply #86
I think yours does have the stinger header.  That won't make boost early like a twin scroll header that you would have to build.  Thats why I built mine.  I should be able to get almost full boost around 2800, at least thats what Ive read on turboford.org :burnout:  Edit: you may want to check your timing too.  When I got my turbo coupe, it still had the IHI, but it was really slow.  went 15.8 @ 86.  Checked it, it only had 5 deg withthe spout out.  Moved it to 14. stock is 10.  Next run after that went 14.97@90.9.  the holset may want more timing but dont know yet, lol.  mines still apart
Reply #87
how did you build yours?  let me know how it works for you.
Reply #88
Quote from: 1WLD BRD;225129
3,500 aint gonna cut it with a holset trust me..
get a 2 step on it and wire it iin the cutch pedal switch but a 4,500 pill it in leave with some boost.
Reply #89
I have to say, that's a pretty sweet ride there! I even like the wheels!
