Topic: Bought a modified '88 Turbo Coupe (Read 13499 times) previous topic - next topic
Reply #90
Thanks Derik, I should have it at CJ this year.  unless it fails the E test, then I wont be able to get it plated it in time.
Reply #91
A twin scroll is a paired header where 1+4 go in one side of the turbo and 2+3 go in the other.  You might have a problem though.  your turbine housing may be ground out.  Actually maybe not because you do have a extenal gate dont you.  I did quite a bit of research on turbo ford before deciding what route to go with it.  heres a couple pics though
