Topic: Complete dash removal - Help with connector! (Read 7066 times) previous topic - next topic
Found a few things (that I already knew) searching...  So how do I get the dash completely out?  I know, 5 bolts, 5 nuts but what else to pull the whole thing as one unit?
Btw, I'm stripping/adding sound material.  Need to get to the firewall...
1988 Thunderbird Turbo Coupe
Just set the wiring harness of the bck of it. makes it a ton easier.
Hmm, I'm not sure I follow what you're saying...  How many plugs are there to disconnect?  Also, anything need to be done with the heater box.  I'm assuming there's a couple vac lines, the heater cable.. what about the vents?  The heater box will stay on the firewall right?
Quote from: booksix;203617
just a few tie straps hold it in once everything is unplugged, one you take the hvac stuff loose it will stay with the harness, and yes the heaterbox is its own assembly.
ok, cool...  Seems simple enough, thanks
I can't remember perfectly, but I believe you have to drop the steering column (I completely removed it for ease).  You don't have to touch the core, just remove the vacuum lines from the back of the control deck.
The hardest part for me was getting the cluster harness through and out of the back of the dash.  I'd mark everything you can as well.  I told myself I'd remember... and I did not.
ahh, so I have to remove the cluster?  I guess it wouldn't make sense for them to have another connection behind the dash.  So what kind of things did you think i should mark?  I can't see there being that much to get mixed up.
Just little stuff...  Wires for the trunk/gas release, auto dim, that blue brake thing on the drivers side, clock, headlight/antenna switches, etc.  It wasn't too hard to figure out but it added some time.
I don't remember if there's another connection behind the dash for the cluster.  I just remember a big mess.
!  I forgot about all those connections!  Hmm....  I have the entire thing unbolted and the carpet out already.  I have from Thursday at 8pm to Friday (my day off) around 11pm to finish pulling the dash, install 2 layers of sound dampening material to the firewall/trans hump and get the dash back in enough to drive it.  What do you think?  :D
You can do it!  Lol I had an "expert" help me with mine, so it wasn't too bad.  Once you get all the wires re-ran it will go smoothly.  Is it really that loud?
driving a 5 liter powered tin can with 2-chamber flows and dumps at 75mph to work everyday....  Yeah, its loud!  Much quieter when the carpet is in...  Hearing this much noise on the inside makes me realize what my neighbors have to deal with!!  :hick:
Good luck with the dash, mat and reinstall. I hope you have help.
I almost blew a nut trying to get the power seat out myself. lol
LOL, been there....  many times!  I just had them in and out several times; my entire interior was just redone leather.  I'm used to lifting those heavy bastages!    One time I couldn't move the car or open the door far enough so I took the passenger power seat out the window and partially across the roof of the car!
lol- Sounds like something i've done before. Next time your in Buffalo you can help me put my seats back in.
hahaha!  you got it!
