Topic: Complete dash removal - Help with connector! (Read 7023 times) previous topic - next topic
just for the record....  this sucks!  back to work
1988 Thunderbird Turbo Coupe
ok, does ANY of this wiring stay connected to the dash?!?
Ok, I'm not taking it all the way out, just rotating it toward the drivers side enough to do the fatmat....  but I now I need help with the heater box.  I got the 3 7/16" bolts out, now what.  Is it glued in place?  I can't find anymore bolts!  Do I need to take it out in a couple pieces?
EDIT:  HAHA, more stupidity due to rushing...  Ok, I'm off to go disconnect the heater hoses from the core in the engine bay  :hick:
Done yet?  Let us know the results!
Hahaha, yeah, going slow.  Once the dash was off I realized I had to pull the pedal assembly and some more brackets as well as the entire parking brake assembly before I could get my fatmat down.  Holy PITA!  I currently have my two layers on the firewall down to the seam in the florboards and am putting this back together.  This is close to where I left off except I now have the pedals and the factory heat guards back in place...  Heater box next...
Oh yeah, and on a sad note...  My dash has suffered a fatal blow (in my mind anyway).  I lost my balance and put some weight on the dash and it flexed a bit too much.  I now have a hairline crack from front to back on my dash...  not cool...  maybe another reason to swap to sn.
the job doesn't look fun at all.
I guess its time to upgrade the dash
Yeah, gonna save up and grab an 01 plus dash and console in the next few months.  In the meantime, I MIGHT get the dash back in tomorrow....  I'm doing a live recording downtown San Diego right now...  Bored to death waiting for the band to finally start...  Blah!!
yea, those musicians are never on time. lol
Ok, I have this all back together...  but I discovered a bare connector on the column that I never saw before...  does it need to connect somewhere?!?
That kinda looks like the wire that goes to the ignition lock cylinder. I believe it's for the key warning chime/reminder...? I can't remember, mine had an issue with that when my mechanic replaced my lock cylinder. We couldn't get that wire hooked up, so as a result, I can have the door open with the engine running and no dinging from the chime. Which is kind of nice, actually. Anyway, that's my guess. It was a single loose wire with that type of connector, and that's where it went in my '86.
LOL, kinda nice...  thats funny!
Ok, so I'll see if it goes there....  Thanks!
Does your door ding with the key in? (before you try to connect it there)
Yeah, I just tried and it does chime.
It is kinda random.  I found it tangled all in with the ignition wiring like it had never been connected anywhere.  Also, it has two wires on it.  Almost as if it was one wire that was cut in two then reconnected by crimping on a female spade connector....
oh yeah, and the car runs...  can't be anything major, just don't want to leave it if it could short out to something...
