Topic: winter resurrection progression (Read 17698 times) previous topic - next topic
Are those Explorer Rims?  What size tires are you running on those?
yup. 17" explorer wheels. that was a test fit, i didnt keep them. tires were 235/45/17 IIRC.
I'll check the tire size.  They are in my garage now :hick:
Quote from: CougarSE;196423
Well, personally, I think that they look pretty good!
:bowdown:  Gumby nice mods :D
gumby,
did you take your headliner out when you were welding inside your car?
If not, how did you protect it from spark burns.
i didnt do any welding close enough to the headliner to worry about it. the roll bar is bolt in, and the SFC's didnt cause any problems.
a'ight been workin on a few things, trying to get some loose ends tied up on the rest of the car so i can start on finishin up the engine bay.
finished up the wiring for the diff temp gauge.
ditched my door lock actuators(frozen), and swapped all the locks in the car. i now have a complete, workin, set of turbo keys for it.
removed the ABS and PRC computers from the trunk area. all the wiring is still there. parring the harness will probly be next winters project along with swappin out my horribly cracked dash.
started on a few more aluminum panels for various places around the car.
the PO wrecked the steel ring around the inner shifter boot and cut a hole in the top of the tranny tunnel, so i made a new panel for that area
also started on my door panel filler plates. the PO strikes again; when i got the car one of the arm rest pads was missing, both arm rests were busted, and half the screws were missing. since i am not retainin the power locks, i jus threw the armrests in the dumpster. hopefuly i can finish up my filler plates and get some pics of them tomorrow.
playin with an idea for the hood as well. since im not runnin a TMIC, i dont want the TC scoops in the hood. i was thinkin about findin a smooth hood for it, still might later on. but in the mean time, i built these plates for the openings. not quite finished yet....
as promised, here are a couple shots of my arm rest delete filler panels. a lil more file work in one corner so it fits just so, and this one is done. the other side is not far behind. attach them to the door panels, and done! reassemble the interior, and move on to other projects with the car.
Reply #39
 thats not bad looking!!
Good work!!
Reply #40
Quote from: gumby;199532
Why no arm rests?
Reply #41
Quote from: thunderjet302;199713
Why no arm rests?
Quote from: gumby;199385
i didnt wanna hunt down new arm rests, pay money for them, restore them if needed......
since im not using the power locks, i dont see a need to keep the buttons in the doors....
im left handed so i drive with at least my left hand on the wheel, no arm rests needed on the door....
etc. etc.
Reply #42
Quote from: gumby;199728
im left handed
ANOTHER LEFTY?! jesus christ. you guys are everywhere.
Reply #43
etc. etc.
Geesh I had two raven ones sitting that I gave to a guy in the Chicagoland T-bird club. I didn't know you need some or I would had let you have 'em for free:hick:
Reply #44
Quote from: thunderjet302;199995
well im glad they went to someone who wanted them and will use them.
i wouldnt have.
