Topic: Chuck's '83 TBird (Read 266150 times) previous topic - next topic
Chuck's '83 TBird
Reply #120
Probably not much racing.  I'd build a car specific for that if I was going to. I wouldn't mind some HPDE stuff, but I'm more just building a car that I want.  The rear susp and diff need some attention anyway, before I would do anything serious.
Chuck's '83 TBird
Reply #121
Quote from: Chuck W;361280
What is the cage for then?? lol Where in the heck did you get those awesome fans, they would give me a lot more room.
1986 T-bird
347 stroker motor
185 AFR Heads
TrickFlow cam 224/232-542/563
Victor Jr. intake CNC ported
Quickfuel Holley 800 cfm
Hooker 1-3/4 long tubes
Custom built AOD
B&M 3000 stall
8.8 w/4.30 gears
UPR upper/lower control arms
Strange shocks/struts
26x10x15 M/T slicks
11.48@119.27
(coming soon Tremec 3550)
The Finished Product
Chuck's '83 TBird
Reply #122
Quote from: 347Thunder;361286
The fan set-up is Derale.
Chuck's '83 TBird
Reply #123
very reasonably priced, but the 50amp draw would kill me, my ford contour fans draw 40amps and that hurts my 180 amp powermaster, might have to get the 200amp one.lol God I don't think my car will ever be done.lol
1986 T-bird
347 stroker motor
185 AFR Heads
Custom built AOD
B&M 3000 stall
8.8 w/4.30 gears
26x10x15 M/T slicks
11.48@119.27
Chuck's '83 TBird
Reply #124
50A?  It's closer to 25-30A  I only have a 30A fuse in the power wire to it.  I'm only running a 130A 3G alt.
EDIT:  I just looked.  It's the 16812 unit.  I only have a 20A fuse in the power wire.  They don't move massive amounts of air, but they do more than well enough to cool the 2.3T.
Chuck's '83 TBird
Reply #125
Quote from: Chuck W;361293
Ive very seldom seen a stock fan turn on with the 2.3T engine.  They must cool themselves well or not make much heat??
Mike
Chuck's '83 TBird
Reply #126
Quote from: mcb82gt;361295
Well, the stock fan switch is set to about 230*F (or way too ed high).  On mine, the MS controls the fans, and kicks them on at 200* and off at 180*.
Chuck's '83 TBird
Reply #127
Ive seen this car for years, always been one of my favorite
Chuck's '83 TBird
Reply #128
Well, I got the intercooler all installed.
I stuck the battery back in it, and fired it up.
Now to bolt the nose back on and fiddle with the tune a bit.
Chuck's '83 TBird
Reply #129
Everything is looking good as always Chuck.
Chuck's '83 TBird
Reply #130
Back together and back on the road.  Only a short drive so far, revealing the BOV had transitioned from a quick "PSSSHHHTT!" to a more obnoxious, and amusing flutter.
More when I'm able to get it out and flex it a bit.
Chuck's '83 TBird
Reply #131
I don't think I caught it but how much boost are you pushing?
Chuck's '83 TBird
Reply #132
Chuck, what size tires are you running? Ive always loved the stance of your car. C springs IIRC? Wonder how they would sit with 302/351...
Chuck's '83 TBird
Reply #133
Quote from: DVP;363063
245/45 front, 255/45 rear.  Still C Kits in the front.  Haven't gotten around to doing the whole coil-over thing yet.
As far as stance goes, it was the same when the car was a 302/AOD, and the two other's I've lowered this way have been the same.  You might need a 1/8"-1/4"  of spacer on the front springs with the heavier combo, but you can never really tell until it's all on the ground.  I might have some old ride height measurements in one of the log books, but we're talking about 15 years worth of notes.
Chuck's '83 TBird
Reply #134
chuck, how do you keep the front wheels from rubbing when you turn  the wheel all the way?
