Topic: Chuck's '83 TBird (Read 266006 times) previous topic - next topic
Re: Chuck's '83 TBird
Reply #495
The replacement radiator showed up at the end of the week, and I finally got time to install it today.
It was a drop-in replacement for the stock one. The only issue was either it's a touch shorter than the stock radiator, or my mounting pads are a little compressed. I needed to add a little bit more to each of the upper and lower isolators to get the hold-downs to "hold down".
The only oddity is that these don't use the same caps as the originals. They use one for a Subaru. The included one with the radiator has sub-par reviews, so I'm picking up a replacement to swap it out.Looks like a Stant 10333 is the crossover.
Seems good so far in the heat cycle to fill things up and test the fan.
Reply #496
Not sure when this happened, but it looks like I need a new bumper light lens.  :frown:
Reply #497
Well that sucks. Am I remembering correctly that the clear lenses were only on the 83’s?
Reply #498
Yup. '83-only.
Reply #499
Sorry to see this.
you might want to consider making a mold yourself:
https://youtu.be/QMe9MOBjkmc?si=amCRmAZdMX4_YOW3
1988 Thunderbird TC, 5spd
'21 F150 Powerboost
'17 Husqvarna TX300
Reply #500
Sorry to see this.
That actually gives me ideas for the reverse light lenses for the LTD wagon that are impossible to find. Not sure if any of the ones I have are good enough for "masters" though.
Reply #501
For the LTD or 'Bird, although the master may not be perfect it will hopefully be good enough that you can polish out imperfections.
'21 F150 Powerboost
'17 Husqvarna TX300
Reply #502
The LTD.
I have a replacement for the TBird on the way.
