Topic: Project Evolution *** Project Complete **** Wednesday July 9, 2014 (Read 1531706 times) previous topic - next topic
Reply #690
OK, I decided to rebuild the trunk by memory. But seeing that I don't trust my memory, this is what I came up with.
The last repair had a straight bend in it, and I noticed it was holding moisture. This time I decided to bend it on a curve, so moisture can travel to the weep holes.
this was a before.
Here you can see the straight bend that wasn't letting the water to the weep holes.
A great afternoon fix, but a bad design on my part.
Here's the start of the curved piece that will let water get out when the lid is closed.
It's tough to tell in this pic, but there's a compound curve in it.
Unfortunately, the only thing I don't own is a shrinker/stretcher.
So I had to pound it out by hand, which really sucks.
A little more fine tuning, and it'll be good.
Also got some of my stuff for surfacing the panels.
This will ensure that the car doesn't have any waves in it when I'm done. ;)
Now you know why I stripped it.
That's all for today my friends.........
Reply #691
I see lots of block sanding in your future. Could you not use a high build urethane primer instead. Maybe save a little block sanding time?
Reply #692
The car needs to be blocked no matter how I look at it. This will do a better job before the epoxy primer goes on. Especially on the panels that got welded.
Reply #693
Most of us would have purchased another trunk lid... but nooooooo, not you!
Just kidding. I bow down to your greatness, lol.
Reply #694
I give you alot of credit for going out there on a consistent basis and working on your car. I know I can't do that.
Reply #695
Quote from: DerikWayne;247143
Most of us would have gotten a new car! LOL.
Jerry I have a question for you. since you brought up the subject of the underside of my SHO. What would you recommend "winterizing" it with? I'm on a budget so I need the cheap route.
As much as I would like to seal/undercoat it I dont think I can afford it right now.
Reply #696
Quote from: thundr306;247146
Thanks,
Being a contractor usually gives me a bunch of free time from Thanksgiving till the end of January (tax return time).
When work start up again, it'll be hit and miss like during the summer.
Reply #697
Quote from: DVP;247147
If I had got another car, I still would have taken it apart and stripped it to the point this one is. This car cost me very little money to keep and rebuild compared to finding one and getting it back to Buffalo.
If I didn't upgrade and add anything extra, It only cost me about $500 to fix it with all the panels and materials I got into it.
As far as undercoating, The spray can stuff would be the cheapest and easiest. I don't know what the underneath looks like right now but if there's rust already, it's gonna keep rusting until you get rid of it.
I may just say that if you have a lot of rust, then don't undercoat it until you can treat it or blast it. undercoating it will make a big mess that you'll have to clean off before you can treat or paint with encapsulator.
A gallon of Zero Rust is only $52. You can do the entire underside of your car 2X  and it would be rustproofed almost forever. then you could undercoat it if you wanted.
Hows that?
Reply #698
Undercoating?We don't need no steenking undercoating here !!! LOL.
Reply #699
I wish I had the time to do this to my car
and tools
and space
Reply #700
Quote from: 347Thunder;247007
All I have to say is, you are out of your brilliant mind! lol
My headache's gettin bigger.
Reply #701
Quote from: daboss351;247215
and tools
and space
And money.
But, having time to do all of this is what makes it worthwhile.  IMO, the best bodymen are the ones who have done it over and over and over and over again.
1987 TC
Reply #702
But when you are a bodyman you never want to come home to work on your own. I only finished my car because I stopped doing it for a living.LOL
1986 T-bird
347 stroker motor
185 AFR Heads
TrickFlow cam 224/232-542/563
Victor Jr. intake CNC ported
Quickfuel Holley 800 cfm
Hooker 1-3/4 long tubes
Custom built AOD
B&M 3000 stall
8.8 w/4.30 gears
UPR upper/lower control arms
Strange shocks/struts
26x10x15 M/T slicks
11.48@119.27
(coming soon Tremec 3550)
The Finished Product
Reply #703
Project is temporarily on hold, due to my dad passing away unexpectedly.
Reply #704
Im glad you didnt buy another car. Its fun to see the insides of our cars. Plus Im learning ALOT. Will the Zero Rust stop the rust? Its not bad but if I keep it I would like it to not get worse.
