Topic: Project Evolution *** Project Complete **** Wednesday July 9, 2014 (Read 1531095 times) previous topic - next topic
Reply #675
You soooooo need a rotisserie LOL so you'd have a much easier time getting all the  off the bottom that you really wanted to.
Reply #676
Next car
Reply #677
You aren't leaving me much of an excuse not to work on my car's underside, lol.  I've put it off til the Rotisserie is done...which is put off til the price of steel comes down.  Keep up the good work!
1987 TC
Reply #678
Quote from: HAVI;246605
It all happens when the time is right. I've been planning this since about 2003. ;)
Reply #679
Today I decided to rebuild the trunk lid.
Drilled out the old rivets and yanked it off.
Did a little measuring, and did some cutting
Then a little fitting
Then a little more fitting
And this is what we end up with
Curve and all
Next is to rebuild the inside again. I hope for the last time
Before I redo the inside, I'll cut the outer panel and put a backing strip on so the replacement skin is in the correct place to match up. When I replace the inside, the panel should both line up with the outer one. We'll see how that goes. LOL
That's it for today.
Reply #680
Jerry, after reading this thread time and again, and seeing the pics of the progress thus far, I'm absolutely convinced you could build a car from scratch with your bare hands!
It's amazing!:bowdown:
Reply #681
Just a thought but on the passenger side you may want to make the tank bracket smaller if you're going to run 2.5" dual exhaust under the car. The top of the passenger side tail pipe will hit it if you use any of the pre bent Mustang tail pipes. Trust me I know ;)
Reply #682
You realize that when you're finished with this car, you would have touched every single inch of it!
Reply #683
Quote from: thunderjet302;246792
Not sure about the smaller part, as I don't know where it would actually hit without having the pipes installed.
I'll deal with that problem as it comes. I also know where to get a 2 1/2" pipe bender just in case.
DerikWayne
You realize that when you're finished with this car, you would have touched every single inch of it!;)
I'm sure there must be some part that I won't touch.
I cut some parts off the trunk today
Oh well, I guess I've seen worse. This pretty much said it all.
But on the lighter side of today.
I ended up making a pattern of my SFCs to send to someone, so they can copy them for their car.
It's got to be the strangest thing I've ever made in all my 25 years in building.
Looks like SFCs for a stagecoach. LOL
Reply #684
Amish SFCs!!
Great work by the way!  I know ill never have half that skill!
Reply #685
:hick:  Could use those SFC's here:
1987 TC
Reply #686
All I have to say is, you are out of your brilliant mind! lol
1986 T-bird
347 stroker motor
185 AFR Heads
TrickFlow cam 224/232-542/563
Victor Jr. intake CNC ported
Quickfuel Holley 800 cfm
Hooker 1-3/4 long tubes
Custom built AOD
B&M 3000 stall
8.8 w/4.30 gears
UPR upper/lower control arms
Strange shocks/struts
26x10x15 M/T slicks
11.48@119.27
(coming soon Tremec 3550)
The Finished Product
Reply #687
I have a friend with 2 87 cougars. One is a two tone blue v-6 with a good trunk lid. He is going to have to get rid of them by the end of the year. I'll bet I could get you a pretty good deal on them. I'll be going to his house this weekend, and I could get a couple of pics for you then.
Reply #688
Quote from: Haystack;247025
I don't see shipping as being user friendly. Especially from out that way. I'm kinda in a bad area to get too, seeing that I'm right between Lake Erie and Lake Ontario with Canada on another side only 7 min. away.
You could see about a price to 14072, But I may have it finished by the weekend.
Reply #689
Sweet!!
I owe u big time!
