Topic: Project Evolution *** Project Complete **** Wednesday July 9, 2014 (Read 1491474 times) previous topic - next topic
Reply #2850
Quote from: daminc;361921
that would be awesome
um, wait what would? I said a lot of stuff
Reply #2851
Quote from: flylear45;361922
When I tried to use a manual boot on an automatic shifter I found that there wasn't enough give in the boot to allow the range of front to back motion, so I went with another plan.
Just FYI.
that's what I feared. that's why I figured I'd make one with the aod cover
Reply #2852
Quote from: sarjxxx;361923
hold on....I might be having to make one again
Reply #2853
Flylear, what did you end up doing... If I may ask
Reply #2854
Jerry, if you can lower the shifter a little, you should be fine with the 5 speed panel and boot. Also, there are other shifter boots you can substitute to fit that are a little taller (giving more movement for shifting), and you still have that look that's "right".
Reply #2855
any lower will need some mods of the car. the one side is on the hump now... I could cut it, and make a box to drop it in to lower it
Reply #2857
I think with a slightly larger/longer boot, it can look factory.
Reply #2858
I'm wondering if the actual shifter itself, the vertical part, could be shortened a little. I don't see why not. I need to snag a Stang piece as a test mule and se what can be done. That would help, and look cool.
Reply #2859
since I joined and over this past month I have been reading this entire tread (a 143 pages later and 90% of it on my phone) and I am amazed what this car looks like and the amount of work into the car from what the project started from..... WOW!!!! ...... I thank you sir for posting your progress and allowing me (and everyone else) to read about this experience I could only wish to complete someday
Once again, Thank you, awesome job on everything, and maybe someday I could be privileged to see the car in person some day
Reply #2860
I'll get you hooked up. let me go through the ones I have for you,
John
Reply #2861
Quote from: dustytheredneck;361953
Everyone here should actually be thanked..... If it wasn't for this place, I would have never found entire panels, and parts to do the job.. most of the people here helped in one way or another to get it this far.. and you never know, one day you may find yourself in Buffalo, NY.... or who knows, It may actually make it to a future Catjam.....
Reply #2862
I'm also thinking about shortening the shifter height. hopefully without destroying the only one I have...lol
Reply #2863
Let me see if I can get one from the Fox Stang at the yard and I can take pics and see what they're made of so you don't do damage that can't be repaired. Next Wednesday.
Reply #2864
Ok I took the top off the shifter... I measure 2 -1/4" of travel on the shifter, park to 1st
so in theory... I could actually move the entire shifter in any location to make it fit into 5 speed cover opening.. all I need is 2-1/4" top to bottom on the cover opening..
Who want's to be a pal and measure their cover for me?
as far as using the original shifter the way it is, I don't see why it wouldn't look good with the boot...
