Topic: Project Evolution *** Project Complete **** Wednesday July 9, 2014 (Read 1491557 times) previous topic - next topic
Reply #2835
I'd bet Hcor has what you need.
Reply #2836
good Idea
Reply #2837
got the H-pipe bolted in.. O2 sensors in... eyeballing what I need between the tail pipes and the H-pipe now.... apparently quite a bit....lol
I hear that, I put my shorty headers and x-pipe on this weekend and it was not a simple bolt-on. lol. I beat, banded, made a small dent here and there, got out the grinder and torch but got it on. My lers will be here tomorrow, I just ordered the summit turbos. Oh, I like the 5-speed boot idea, I did that on a firebird once.
Reply #2838
Glad I didn't have to go through all that... I just heated and bent the hangers in about 1/2"... and it bolted right up...now I have to fill in the 52" between the H- and tail pipes.... lol
Reply #2839
I also used the pipe hanger from the SC... it was still on the AOD and it seemed to work fine. I don't know if they're the same as the stock version
Reply #2840
hmmmm.  I'm thinking I could just use the AOD shifter cover and a boot... mainly because the shifter is off centered to start with.  I could mod it to work with a boot maybe
Reply #2841
Cutting a hole to fit the boot would be easy. One the factory 5 speed panels, there are pins molded into the plastic on the bottom that the boot slips on to, then little metal clips hold the boot to the panel. Either way, It wouldn't be hard to figure it out. BUT, on the 5 speed panel, it rolls down into the boot....meaning, the hole for the shifter has a concave roll to it...if that makes sense.
Reply #2842
you got a pic of one?
Reply #2843
Here's mine. You can see how the edges of the shifter boot hole roll down. A finished look.
The panels aren't too hard to find. The boots are also easy.
Reply #2844
yea. that will probably work
Reply #2845
Check this.....
http://cgi.ebay.com/ebaymotors/FORD-MUSTANG-AUTOMATIC-PISTOL-GRIP-SHIFT--POLISHED-/290498690256?pt=Motors_Car_Truck_Parts_Accessories&hash=item43a3123cd0
Reply #2846
jerry I got a 5 spd shifter panel if you need it... yours for the cost of shipping.
...which shouldn be much.
Also, I might be able to get you a 5 spd boot from the local yard but I don't remember for sure or not just how much stuff was left on that console.....
edit: actually I'm headed up there right now so I'll take a look for you when I get there
re-edit: ok now I'm not but I'm going tomorrow so let me know what you would like me to look for and I will for you
Reply #2847
The older 5 speed Taurus SHO share the same shifter boot.
Reply #2848
Quote from: sarjxxx;361909
that would be awesome
Reply #2849
When I tried to use a manual boot on an automatic shifter I found that there wasn't enough give in the boot to allow the range of front to back motion, so I went with another plan.
Just FYI.
