Topic: Project Evolution *** Project Complete **** Wednesday July 9, 2014 (Read 1490756 times) previous topic - next topic
Reply #2670
Actually, I may have them in mine...Vinnie sent me some springs, and when I put the car back together with the new tubular parts, the rear dropped about 1 1/2" from the original springs.
Reply #2671
perfect example...
stock rear, and springs
and immediately after the entire rear end swap...
Reply #2672
Yeah, I want to get some CHE adjustable lowers eventually for mine.
Reply #2673
I now see that I should have got the adjustable lowers
Reply #2674
my 87 is identical to yours (or was i should say), and it also sits and always has sat higher than my 20th.
i think having quad shocks in the rear will make it more tricky for me to adapt the profile so the installed new shocks are placed at a higher point.
I dont think i need to adapt the horizontal shocks, just the ones that pass through the trunk.
Reply #2675
I thought about an adapter plate for mine... Not sure how I would bolt it on so there's no movement between the rear and the shock without welding..
Air shocks seem to be an easier solution right now.
Reply #2676
I had the Ford Motorsports handling kit for the T-Bird and the rear on mine sagged for quite some time. This summer I decided to try to level it so I got the SN95 Mustang rear coils for it and it went even lower. Then I got a set of Fox body Mustang rear coils for it, they brought it up but not quit to the hight of the Motorsport coils. I was thinking of going with air shocks but decided to try a set of factory rears from an 87-88 cougar at the jy. To my suprise they leveled it. So now I'm thinking the front Motorsports coils weren't lowering coils at all. It sits level now and I'm happy with it even though it does sit higher than I'd prefer. I like my wheels I have now but they're 14s and I'd like to go with 17s someday. But they're not on my must have list at the moment.
Reply #2677
I have air shocks on the Sport. Reason.....When I'd carry a heavier load,like groceries,I'll air up the rear so it'll sit level with a months worth of stuff,then when I unload,I just let a little air from the shocks. The doa great job. I have the schrader valve on the tail light panel....When I open the trunk,it's right on the back driver side area outside the trunk seal so it's hidden from view ,yet super easy to access.
Reply #2678
got my headers... now I can start putting everything back on the motor.
No problem getting to these plugs now..
My favorite part is the tag on them...lol
Reply #2679
Those are pretty , do they need a special h-pipe
Reply #2680
Why did you give up on your header project?, The new ones are nice though. Oh yeh I wish I could of used those vc covers,you got them looking nice.
Reply #2681
they wouldn't clear the frame on either side... Going to try and use them on the vert
Reply #2682
I wouldn't think that they would need a special h pipe...
And these things weigh a freakin ton..... bet the front of the car went down some....lol
Reply #2683
Hey Jerry I thinking, I know it's scary, but once your front end goes down with more weight your ass end is going to raise a little. It may just work out right.
Reply #2684
I'm hoping the same. I didn't realize stainless headers would weigh so much..
