Topic: Project Evolution *** Project Complete **** Wednesday July 9, 2014 (Read 1489964 times) previous topic - next topic
Reply #2595
Don't you need to flip the shifter arm on that one? I can't remember how mine was.
Reply #2596
Quote from: Kitz Kat;337732
I still have to see about that. let you know later today after I look at my old AOD (thinking the bolts are also with it). if they match, it needs to be flipped. ;)
Reply #2597
I have one of each kind, I can take a look if needed.
1987 TC
Reply #2598
It says on Coolcats, that the arm needs to be pointing down for floor shifter, and the column shift will points sideways.... looks like I'm good to go for that..
Reply #2599
I'll look at mine to it's at work.It might be right I can't remember.
Reply #2600
just looked at my old aod. It's flipped up...... opposite of the new one
Reply #2601
Ok, Jerry, come clean. Where did you hide the flux capacitor? Or was the wrinkle in the space-time continuum untintentional?
Reply #2602
Lol.. I hate when that happens.....We like to call that "folding space"
I got this new medical grade sealed keyboard last year, and I still can't get the hang of the keys. lol
Reply #2603
the aod  from the column shift 3.8
and I think this is the last of the parts.....
I'm going to twist up some brake lines next..... and it will be time to put that baby in. But that won't happen until at least the 23rd of this month I'm going away for a bit first. If I have time I'll do the brake lines before I leave.
Reply #2604
Quote from: Thunder Chicken;337745
What is really amazing is  October 25th is the day that Marty McFly went back in time , wow :D
Reply #2605
and, I didn't type 25 when I updated
Reply #2606
I looked at my shifter and it's down. so yours is right.
Reply #2607
Quote from: Kitz Kat;338139
Finally..... Something I didn't have to re-do, repair, or rebuild.. ;)
Reply #2608
So I figured I could bolt the AOD to the motor today.....
First I had to modify the lift plate.....
then after I got the motor off the stand, I realized that I was missing a bolt because the last person that put the C6 in the car, didn't put all the bolts in the flexplate. So now this is what I have until saturday when i have more time....... still parts everywhere and no closer to putting it in..
Reply #2609
Closer by the day.Everything is looking great. A couple of questions....are you using the high torque mini starter? You are using the correct bolts for the flexplate.right?
