Topic: Project Evolution *** Project Complete **** Wednesday July 9, 2014 (Read 1528844 times) previous topic - next topic
Reply #1815
An Explorer timing cover will work?I didn't know that.Will a standard 5.0 water pump work or is it different for the Explorer.I didn't pay any attention when I pulled my Explorer engine apart.I MAY have an Explorer timing cover in the garage.
Reply #1816
think he meant the intake cover....BTW I got the stud out of the chain cover. now I need to find some new ones.... Any ideas where to find some?
Reply #1817
BTW. I'm typing this from the new shop... Now I need to set up the "Evolution Cam"
Reply #1818
What do you mean by "stud"?Is it a bolt with a built in nut and more threads for a nut to hold a bracket?
Reply #1819
yes
Reply #1820
I have a few new ones (and a couple of nice used ones).I'll bag 'em and ship them to you along with the extra seals and gaskets I have from my Explorer engine assembly.
Reply #1821
You the man
Reply #1822
I try to keep my end of the "agreement".LOL.
I'll let you know what I have in a little while so you don't buy things you may not need.
Reply #1823
I have the following to send you...
water pump gaskets
the long water pump bolts you need (new)
timing cover front seal
That's it so far.I've got to do some more looking around out there.
Reply #1824
Today''s adventure
started cleaning everything from the motor.
first off, this is the long bolt. The other one snapped.
2nd...... since I'm not a redneck. this is my Polish parts washer.
A left over laundry tub, a submersible pump, and a section of hose. it drains into a 5 gal bucket, and recirculates.
enjoy
and all my squeaky clean parts.
I seem to have a little rust on the oil pan. I thought it was all oil and gunk. guess not.
and the rest of the stuff that made it's way into my Polish parts washer.
and the rest of the parts to clean up.
Reply #1825
Nice start on the engine project.Remove that seal from the front cover.I'll be sending you a brand new one.Are you even cleaning all of the parts that you won't be using?Media blast....prime and paint...
On another note,I saw the starter in the bucket.Get a smaller high torque starter.They rock.I got a "new" reman starter off of an Explorer 5.0 and it has been great.Super easy to wire (just add one wire),and there you go.It also relieves the car of a lot of weight.
Reply #1826
Being a fellow Pole, I'm interested in your parts washer.  What pump did you use for the washer?
Iv'e been thinking of doing the same thing myself.  I have a spare dishwasher pump that should work.  Also, I planned to use a "clay sink" design.  Basically a bucket within a bucket.  The silt and junk drains into the inner bucket, then the water runs out over the top into the outer bucket.  The pump sources from the bottom of the outer bucket.  This way the heavy grime sinks to the bottom of the inner bucket helping to prolong the life of the pump.
Brake-clean has ruined about every pair of jeans I have.
Reply #1827
Quote from: vinnietbird;306429
Just doing the parts I'm reusing. The starter is out of here. I can barely lift the stupid thing. lol
Reply #1828
Quote from: 88CougarGT;306431
I used an extra pump I had for draining the pool cover in the old days. any submersible,or piped pump should work fine. your setup should work good.
Reply #1829
Love the grocery store shelves. :rollin:
