Topic: Project Evolution *** Project Complete **** Wednesday July 9, 2014 (Read 1528843 times) previous topic - next topic
Reply #1800
Does anyone know where to find the stamped ID # on a block?
Reply #1801
Hey very good !!
well well well I'm also repairing my car,
a bit of metal work until at last able to paint it
Good luck with your work.
Greetings to all
Reply #1802
Welcome, I feel privileged that this was your 1st post.
Post up some pics of your car
Reply #1803
better be careful jerry, that primer will grow on ya,......lol jk ,. lookin goood man,, thought itd be done by the time i got back on here!!
[/IMG]
Just enjoyin the ride!!!!
Reply #1804
The vert, and building a shop slowed me down a little bit. but I'm in no hurry now that I have another cougar to drive around. It takes the pressure of wanting to cut corners to finish it.
Reply #1805
Todays update
Got the heads back from the shop today
Took the rest of the motor apart
and started cleaning up the intake.
Reply #1806
There's some serious stretch going on in your timing chain.  Good thing your tearing it down, you would have had a hell of a time timing the engine.
Reply #1807
Quote from: 88CougarGT;306306
I'll say..... I can almost take the chain of the gear without pulling anything apart. :hick: No wonder this thing was running like a scared rabbit.
Reply #1808
So,what are the plans for the intake?
Reply #1809
what do you mean?
Reply #1810
are you painting or polishing it?
Reply #1811
Neither, I'm keeping it a satin finish. Then I'll satin clear coat it. All the aluminum will be done the same to match the silver paint that is under the hood. the motor will be black, and valve covers will either be stock covers painted black, or eventually I'll get some finned to match the intake. the grooves of the upper will be satin black to match the motor and the accessory brackets, hood hinges, and stuff like that.  the top cover plate, depending on what I put on there will also be silver satin and black. which reminds me.... I need to find another one of those. this intake only has 2 holes for the cover to attach. The search for parts never ends..
Reply #1812
I made my own intake plate from a piece of s aluminum.It's smooth and polished.I like the look.I like your ideas for the engine.You should have it done by next Friday shouldn't you?LOL.
Here's mine.I have "Cobra" valve covers on it now (the new engine won't).Also,the small area where you can tell I cut off the little cable appendage on the finned part of the intake will be gone.I'll "re-fin" those little spots.The intake plate is somewhat visible.It took about 15 minutes to make,and about 30 minutes or so to polish.
Reply #1813
depends on the chain cover. ;)
Reply #1814
Get an Explorer cover for it, I have one and loved it
