Topic: Project Evolution *** Project Complete **** Wednesday July 9, 2014 (Read 1538459 times) previous topic - next topic
Reply #1020
Quote from: jcassity;259826
i smell the sent of some 2''x 4'' tube steel.
your sniffer must be a little off today. :D
Reply #1021
Armor plating?Bullet proof really is the way to go these days.LOL.
Reply #1022
What kind of paint are you going to do on it?
Reply #1023
Paint?
which part?
Reply #1024
Just have truck bed liner sprayed all over it instead of painting it.With all of the chassis work,and rubber paint,you'd be unstoppable !!!!
Reply #1025
Rubber would be cool, It would save time in the waxing dept.
It would be like driving a giant super ball.
Reply #1026
I went back and looked at the beginning of your project and your car has come a loooooooong way. Keep it up, it make me excited to start mine.
Reply #1027
Quote from: 86XR7project;259946
I bet that was a long read.
Thanks, I'm glad my little project helps motivate others. Wait till you see the next one after this.
Reply #1028
Jerry, On that next project you need to have a film crew on hand to tape it because you never know who's gonna watch this dude. :poke:
Reply #1029
Maybe I should of said what type system are you going with.like base and clear or something no ones ever heard of!!
Reply #1030
ahh, I see.
I'm probably going to use BC/CC. I'm going to start with the engine compartment when I'm done fixing it, so the motor can go back in, and I can finish the rest of the body work.
Reply #1031
Took me 2 years to put my sub frames in yesterday, only melted 1 fuel evap line, but there finally in.A far cry from what your doing or did.
Reply #1032
It should be drivable by next week then,right?
Reply #1033
Quote from: Kitz Kat;260106
And I bet you didn't take a picture..............
A couple of pics today. Here's the passenger side frame repair.
So far the other side seems to be Ok.
This side had a little rot underneath the frame, so i decided to cut out the entire end for replacement.
my plan is to replace the frame first, then rebuild the tower and surrounding metal
I also had my work inspected today, Seems the back end passes with flying colors, and the front is coming along great.
baxo say's 2 thumbs up
Reply #1034
Quote from: daminc;260206
I also had my work inspected today, [COLOR="Magenta"]Seems the back end passes [/COLOR][COLOR="Magenta"]with flying colors[/COLOR], and the front is coming along great.
TMI gross:shakeass:
1986 T-bird
347 stroker motor
185 AFR Heads
TrickFlow cam 224/232-542/563
Victor Jr. intake CNC ported
Quickfuel Holley 800 cfm
Hooker 1-3/4 long tubes
Custom built AOD
B&M 3000 stall
8.8 w/4.30 gears
UPR upper/lower control arms
Strange shocks/struts
26x10x15 M/T slicks
11.48@119.27
(coming soon Tremec 3550)
The Finished Product
