Topic: TC Chronicles --- Engine Assembly (Read 14069 times) previous topic - next topic
must be nice to have some cash and a good car as a base
The stock 5.0 fuel rail bolts right up like it belongs there (On the GT-40).I have an Explorer intake on mine.I had the hole for the ACT sensor drilled and tapped,as well as the water line at the rear of the passenger side of the lower.
claude is using a truck rail. required a spacer on a regular HO upper to clear the regulator
Thats right...
I will be picking up a set of GT40P's tomorrow :)
are the truck fuel rails like the sn95 rails?
1979 Ford Fairmont
[/B]
No. I made a thread on it..  They are unique and only usable or desired when converting a TC to 5.0 and keeping the TC hard lines.
ah, okay i remember reading that.
carry on!
1979 Ford Fairmont
[/B]
Ok time to spill the beans.
These will be strapped to the side of this motor.
Attached to these...
Rebuilt stock short block with ARP Main bolts, ARP rod bolts and ARP head bolts..  GT40P heads and an Explorer intake.. All will be ported before being installed..  Twin IHI's at 10psi,  I'll be using 30lb injectors or 35's if I can find a 8.  They will do for 10psi..  I figure the IHI's will be capable of 15psi before they are done.. but 10 is the number for now..
A tweecer and an A9L will be controlling this.  Probably a 75mm maf as well..
fornicatein' A man!!!
I think you should modify the TC badge to say TT Turbo Coupe
Just a thought
Reply #39
that's more like it.
87 thunderbird turbocoupe
06 pontiac g6 gt
:birdsmily:
Reply #40
Yeah, there is no way in hell I'm going to run a stock engine..
Reply #41
NICE i knew it!
will the IHI's breath free enough?? well running two i would guess they would
Reply #42
The IHI's are just to get the car running under boost.. Later they will be replaced.
Reply #43
What are you shooting for power wise?
Reply #44
Car should be at 300hp N/A.. over 400hp boosted.  And thats conservative..
