Topic: TC Chronicles --- Engine Assembly (Read 14097 times) previous topic - next topic
Reply #45
good to see that 600$ is going to good use :D
Reply #46
Just found a set of GT40P's for $100 less.. I'm going to pick those up tonight :)  Along with the intake manifold :)  Mike I'm going to be sending you the M/O tomorrow..
Reply #47
 Skippy man!
Reply #48
for what it's worth, i've seen BONE stock 302's with a home made single t3 turbo setup make 390 horse and 440 torque at the wheels.
87 thunderbird turbocoupe
06 pontiac g6 gt
:birdsmily:
Reply #49
So I'm really underestimating myself then...
Reply #50
with a set of good sized turbos, forged internals, and a good fuel system, your block will be your limiting factor.
06 pontiac g6 gt
:birdsmily:
Reply #51
Looks like I will be going with an F303 Cam unless anyone knows of a better camshaft.
Reply #52
Quote from: turboranger91;169877
How much boost and what series T3 was he running?
Reply #53
Quote from: JeremyB;169889
it was a t3 from a turbocoupe... one of my old ones.  i "think" he was running about 8-10 psi, but honestly i don't remember... this was years ago.
06 pontiac g6 gt
:birdsmily:
Reply #54
Quote from: CougarSE;169887
i don't see any problem running an alphabet cam.
06 pontiac g6 gt
:birdsmily:
Reply #55
Comp Cams XE266HR....nice blower and turbo cam. I would leave the antiquated alphabet cams alone.
88 TC with 93 GT 5.0 (.030 over), XE266HR Compcam, SVO 1.6 Roller Rockers, BBK underdrives, BBK 1 5/8" headers, 2 1/2" exhuast with Americian Thunder Flowmaster lers. Tremec 5 speed and 3.73's and alot of other goodies to list.....
Reply #56
Holly  thats a big camshaft.  Wouldn't that cam make in town driveability horrid?
Reply #57
it's not too bad.
Cam Style:    Hydraulic roller tappet
Basic Operating RPM Range:    1,600-5,600
Intake Duration at 050 inch Lift:    216
Exhaust Duration at 050 inch Lift:    224
Duration at 050 inch Lift:    216 int./224 exh.
Advertised Intake Duration:    266
Advertised Exhaust Duration:    274
Advertised Duration:    266 int./274 exh.
Intake Valve Lift with Factory Rocker Arm Ratio:    0.544 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio:    0.555 in.
Valve Lift with Factory Rocker Arm Ratio:    0.544 int./0.555 exh. lift
Lobe Separation (degrees):    112
Intake Valve Lash:    0.000 in.
Exhaust Valve Lash:    0.000 in.
Computer Controlled Compatible:    Yes
Grind Number:    FW XE266HR-12
06 pontiac g6 gt
:birdsmily:
Reply #58
that's the one. The thing I love about it is when i'm in third gear and the tach and speedo are as one, climbing. past 3000 rpm and that car is gone.
Reply #59
All of this "twin turbo","horsepower and torque","how fast will it go","power",talk.It's rediculous.We should all be worried about conserving fuel,global warming,and saving trees.LOL !!!!
