Topic: TC Chronicles --- Engine Assembly (Read 15227 times) previous topic - next topic
Reply #120
well turns out my camshaft is a Comp Cams 276HR.  I'm not upset as this is a good turbo camshaft :)  $300 new too :)  I didn't pay near that :)
Cam Style: Hydraulic roller tappet  Basic
Operating RPM Range: 2,000-6,000
Intake Duration at 050 inch Lift: 220
Exhaust Duration at 050 inch Lift: 224
Duration at 050 inch Lift: 220 int./224 exh.
Advertised Intake Duration: 276
Advertised Exhaust Duration: 280
Advertised Duration: 276 int./280 exh.
Intake Valve Lift with Factory Rocker Arm Ratio: 0.544 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio: 0.560 in.
Valve Lift with Factory Rocker Arm Ratio: 0.544 int./0.560 exh.
lift  Lobe Separation (degrees): 114
Intake Valve Lash: 0.000 in.
Exhaust Valve Lash: 0.000 in.
Grind Number: FW 276H-R14
Reply #121
Sounds like a nice cam. Comp makes a very good product. It might be a little weak down low (under 2,500 rpms) but it'll pull like hell up high:D
Reply #122
Yeah she wont be a power monster on the bottom but thats what the 5 speed is for :)
Reply #123
What springs did you wind up going with?
Reply #124
a lot of times custom cams are ground by comp/crane. the builder just sends his specs to them, and they cut it.
1979 Ford Fairmont
[/B]
Reply #125
This one has the part number machined on the end...
I just got back from Jegs an hour ago with a set of crane valve springs..  Decent price and spring rate of 330#  they take a .580 lift.
Reply #126
Quote from: CougarSE;173476
Should work great:D
Reply #127
77mm Pro-M and 24# injectors came in the mail.
Reply #128
24's with twin hair dryers?? that's asking for trouble!
1979 Ford Fairmont
[/B]
Reply #129
the 24's are for the n/a mock-up motor
Reply #130
Yeah the 24's will be for n/a.. The engine will be in the car n/a for a while.. until I can afford the rest of the turbo stuff..  I was going to go with 30#ers but I think I will up it to 42's.
I just mounted the timing cover on the engine.  I was going to do more work to it but I'm getting dragged to steak and shake.
Reply #131
Quote from: CougarSE;169887
Looks like I will be going with an F303 Cam unless anyone knows of a better camshaft.
I'm glad to see that you didn't get the F cam. I think the cam you got with the 114 LSA will be alot better.
What are you doing for an intercooler? I was going to run 2 87 TC intercoolers up front for my set up. 1 for each turbo and Y them together on the outlet side.
Anyway, good luck with your project. I sold most of my turbo stuff because I got cold feet... I didnt think I could pull it off. I'm lookin forward to hearing how that thing is gonna run. It should be a beast!
Reply #132
Quote from: vinnietbird;169923
All of this "twin turbo","horsepower and torque","how fast will it go","power",talk.It's rediculous.We should all be worried about conserving fuel,global warming,and saving trees.LOL !!!!
Well, he is building a hybrid........
It will burn both gas and rubber:rollin:
Reply #133
I'm going to get one of those ebay intercoolers.. probably the one with the dual inlets single outlet.
