Topic: TC Chronicles --- Engine Assembly (Read 15271 times) previous topic - next topic
Reply #105
Depending on what camshaft I go with.  Right now I'm looking at a Trick Flow Stage 1, if I go with it I wont have to go with new springs.  Now I've been looking at a Stage 2 as well, If I go with it I'll have to get new springs..  Rockers are just not in the budget at the moment.
Reply #106
If you spin the motor to 6000 RPM or above with a TFS 1 (which you SHOULD) I'd get new springs......
Reply #107
Whats your opinion on Trick Flow valve springs?  They are a little over $130 bucks.
Reply #108
Came home to find this on my door step :D
Reply #109
Quote from: CougarSE;172276
  Just say no to ford blue.
:raspberry
Quote from: V8Demon;172351
Yeah I have a .533 lift Comp 266HR cam and I had the machiene shop put in high lift Comp valve springs. I spin the thing to 5,500 some times and with the stock GT40P springs I'd get some valve float :hick:
Reply #110
Just bought a Keith Craft Turbo Cam..  224/224@50  555/555 114
Now I need to get a set of Valve springs and I'll have a nice little combo.. :)
Reply #111
Came home today to find this sitting by the door.  Man I'm loving this!  :hick:
Thanks Tommy!
Reply #112
They are a good piece, but there are (according to a few engine builders) even better ones out there.  I have the Trick Flow springs that came with the Twisted Wedge heads I have and they seem to be doing just fine.  Here's some good reading:
http://sbftech.com/index.php?PHPSESSID=3115750724f68c38814e793ad807dd6b&topic=7615.msg68399#msg68399
http://sbftech.com/index.php?PHPSESSID=3115750724f68c38814e793ad807dd6b&topic=1466.0
http://sbftech.com/index.php?PHPSESSID=3115750724f68c38814e793ad807dd6b&topic=150.0
Reply #113
nice shifter!
that is a billet plus though(same as mine), not a competition plus. ;)
Reply #114
Well you remember how much in awe I was about your shifter feel.. This is gona be perfect :)
Reply #115
Claude, your cars just keep getting better and better :)
Reply #116
Well Jim came over today and we got the heads bolted down.. Used that fancy coper spray on them.. Very sticky stuff.  The intake is just sitting there because it looks pretty :)  Going to go find a pipe tap for the ACT sensor tomorrow.
Reply #117
Cool:D
Mine looked like that once.......in primer.......before the FORD BLUE:hick:
BTW you do know that the GT40 and GT40P heads use the same spark plugs. :D
Reply #118
Sure do.
Reply #119
Came home to find my Keith Craft turbo cam sitting on the door step :)
