Topic: Making some progress- FOR SALE (Read 52957 times) previous topic - next topic
Reply #165
Sorry, no progress at all. Been too busy playing with the motorcycles. Getting the itch to get it going again.
Reply #166
Hey Jim check my thread tomorrow night. It will have some motivation, I'll have 408 itches for ya!
Reply #167
I'm back for an update. I finally decided that the car was close enough to being completed for me to drop it off somewhere. They will be finishing up some loose end and taking it to be dyno tuned. I hate to do it, but I just don't have the time lately. I should be delivering it around the end of the month.
Jim
Reply #168
Quote from: thundr306;234621
Jim
That sounds nice. Whatever gets it done. I cant wait to see it al together and going
Reply #169
Kills some of the pride, but I want to drive it. It is finally off the jackstands and ready to be pulled onto the trailer. Just waiting for a phone call.
Reply #170
Quote from: thundr306;235509
You worked for the money so its still your effort going into the car.
Reply #171
My drop off time got delayed. I wanted to make sure there was enough fuel supply.
Reply #172
Reply #173
I have learned some things while installing the fuel system:
1) make sure you get fuel rails that clear your distributor
2) tighten fuel rail fittings before installing rail
3) an fittings are expensive
4) working in a painted engine bay is killing me
5) there is not much room for fuel lines
I will try to post up some pics tonight. I am hoping my return will not be too close. I only have an air gap between it and the downpipe. The downpipe is JetHot coated and the lines are wrapped in 2000 degree foil.
Reply #174
That might work.... LOL
Is there any other wa to route the return line? that doesnt sould like alot of fun and I would hate to see this go up in flames
Reply #175
With the location of the regulator, I really have to run the lines where they are. The passenger side is tight with the downpipe and the crossover pipe.
Reply #176
nn
Reply #177
Header wrap the down-pipe and the fuel line. Then do the foil over the line.
 That should be enough to keep the heat down. :hick:
Matt
Reply #178
Hey Jim-your car looks like it's coming along real good. Number 3 and 4 spark plugs look like fun to change. I hope you change your mind and finish it yourself-from what I saw you were doing a very nice job.
Reply #179
Quote from: thundr306;224005
There are some pics floating around, but none with it on the ground/outside yet. Soon, hopefully.
Good time for those outside shots eh? Unless your hiding all new paint and don't want to post pics. :rollin:
