Topic: The "Stinkin Lincoln" is being striped!!! (Read 52787 times) previous topic - next topic
Reply #375
Quote from: daboss351;221435
intake valves cause they are the smaller valves
umm, the exhaust valves are smaller than the intake's.
1979 Ford Fairmont
[/B]
Reply #376
i made a guess
I was wrong
correction i guess its exhaust valves that are pure white, all except one is black
all plugs are white
Reply #377
I hear someone got a welder
Reply #378
yep
waiting for my brothers friend to drop it off.
his friend is my saving grace
let me use his brand new in box engine stand(the one my 302 is on), his hoist, the welder hes giving me, and he payed for the grade 8 bolts I got to hold the motor up. He's been great
Once I clean out the shed some, im gonna start into the motor some. Pull the lifter reatiners, lifters, timing chain, and cam. I wanna try and see what condition the stuff is in, and attempt to figure out what the hell its got for a cam!
rainy weekend so no body work updates on the linc, but update for me, im single and 100% happier now! Means more time for work, and the car. Hell yes!!
Reply #379
Friends are a good thing, aren't they?
You should be able to do some panel work with a flux core welder.
I've never used one for sheetmetal, but I hear it works.
I can see some SFCs in your future too. LOL
I'll be waiting for the new updates.
Reply #380
yea im gonna try to make some
I ummm "borrowed" some long lenghts of square tubing, angle, and some 1/2 flat stock from my school shop class, so I wanna make front and rear strut bars(only doing a rear because this car is FAT and if i can get any flex out of it, GOOD) and possibly SFC's if i dont buy some.
Reply #381
Quote from: daboss351;221452
It would be cheaper buying the tubing and making your own SFCs.
Unless you already borrowed some tubing for that.
Reply #382
got to borrow a nice 30 footer of square tubing
what kinda of tubing did you use? like thickness
Reply #383
10' 2x2 .120 (1/8 inch, I believe that is)
20' 1x1 for crossbraces and jack rail (optional)
Reply #384
Hard to tell in the pics but does it have valve reliefs?,
sort of looks like it.
Reply #385
yep sure does
its a 5.0 e7 headed truck motor, so its a 5.0 ho pretty much
Gonna clean up and sell the heads, and gonna serch the cam for a part numberits in  good shape, I ben pulling parts and finding nothing wrong
other then I got no oil pickup
Reply #386
threw 65mm explorer tb on the car today
throttle response is insane now(compared to before) Check engine light and idle problems are gonna now too!
got a new front fender on it, got to go get the other fender, rear bumper, and other odds and ends off a mark they JUST got at the yard. Scored a set of fog lights too!
pics coming soon
O and needs new tires, 2 keep going flat
AHHHHHRYGHHGHJKHHJ
Reply #387
still have to mod the TB to hook to the throttle cable!
Reply #388
What did you use for the cold-air intake? MAF or SD? I'm running the stock airbox with K&N filter and the resonator removed, but I'm wondering if a cold-air intake might make sense, especially since I have a 65mm TB, bored-out upper, 19# injectors, and "more cam" (whatever the mechanic means by that, LOL).
5.0L Speed density
Explorer intake
'92 Mustang GT cam
GT-40 racing heads
Unequal length headers
Custom-made duals
19# injectors
65mm TB
AFPR
T/C header panel
11" brake upgrade
T/C rear sway bar
Reply #389
its a used cheapo mustang CAI kit for SD I payed 60 for it, and its been a nice mod, you can really hear it when you punch the gas down, and now with the TB, man the sound and response from jsut taping the gas is awesome!!
you can see it better in this older pic
