Topic: The "Stinkin Lincoln" is being striped!!! (Read 52875 times) previous topic - next topic
Reply #360
Well im not happy
of course I get a 4 day weekend, and im sick so the progress on the car is at a halt. The way im looking at everything I got a long ways to go before I'm driving this thing
Im stuck on a decision now
I can pick up this motor, and I already told the guy I would
Its a roller block, new cam, roller lifters, double roller timing chain, different from stock heads, no intake or timing cover. Now do I spent the hundred and grab the motor, or do I save the hundred for possible stuff on the car..... Im not sure as to what cam or heads are on the motor, and it does have a knock im told, but very little. He said it pulled real hard, harder then the stock replacement he replaced it with. Should I just grab it and sell off parts of it if needs be? I really wanna have something for a motor project, and if it turns out to be gt40 heads, and a good cam, im saving lots of money with a solid valvetrain.
The car needs the exhaust installed, an allignment, and I think that about it for stuff I cant do myself.....
Need some opinions here.... Also I am getting a gt40 upper and lower on a trade of 2 sets of refurbished mark 7 dew wipes so thats CHEAP....
Reply #361
If there's nothing wrong with your engine,save the money and use it later on upgrades.There's always another 5.0 out there.Get well soon.
Reply #362
My motor for the most part is ok I think. It doesnt seem to have been beaten, but it wasnt babied. Has some clatter in the valvetrain, and since I got it, I havnt been easy on it, pushing it past redline to 6k a few times when it was cold.... Stupid, but didnt think much of it then.
thing is finding one cheap around here isnt easy.
A 5.0 mustang lasts about 2 days at a s yard, they are brought in and GONE.
5.0 exploders and mountianer's? gutted for the 5.0. This block I know because the timing cover is off at least has a over 60 dollar double roller timing chain. And the plugs are at an angle, thats gt40 heads right? or are they p heads? All I know is I dont think they are e7 heads.
So ive been thinking, looking into money savings and Im gonna grab it before he advertises it for sale. If its gt40 heads that 100 saved, timing chain theres about 60-70 bucks. If its got the new lifters like its supose to thats over another 100.
I have access to a stand, Gonna be pulling in some  good money in the summer so I'm gonna build a NICE DD motor, and get all the stuff for a 5 speed swap. If I keep this car, it will go in this, if not, it might go in a bird/cougar/another mark/ or a stang, depends on how well this car holds up, and what else I find resonable.
Reply #363
You could also get a good motor in a bird or cougar, If thats what the next project may be.
I'm sure it's a good find for a motor also, sounds like you need to make a list of pros and cons, with the rising gas prices.
gas is $4.30 a gallon over here. Don't see many people cruising around this weekend
Reply #364
we still at 3.90 here
at the moment I dont need fuel effiecent car, so Ill do this for now
bird 5.0 is flat top pistons, SO heads and intake so I'd have to get alot more stuff. Worse comes to worse, I can sell it off at a later date. Its only gonna be a mild motor, nothing insane, just something to move my boat easily, and get ok mileage
Reply #365
Bought it!!
What a  steal!!! its just  5.0 with E7 heads. New freeze pluds, double roller timing chain, newer cam, looks like the block was done, the criss cross pattern is still in the walls!!! The motor didnt run right, all the pistons have serious carbon build up, and the heads have one pure white valve, and one dark black one.
plugs are pure white as well.
found out my neightbor works at a machine shop and offered to help set me up with machine work, a cam, part cleaning, and advice.
Im pysched, never expected to find a decent neighbor around here!
Reply #366
Makey the car so you can drive it around :mullet:
Reply #367
the car does
got to get the body work done hahah
Reply #368
I thought the brakes were still fubar.
Reply #369
nope
replaced every single brake line, all calipers, all rotors, and all pads.........
bye bye 350 bucks.......
Reply #370
see the white valves, anyone know why??
Reply #371
running lean? just a quess
Reply #372
yea thats my thought
i wonder if this cam was to much for the SD system in the van and it ran bad.
I wonder if I can figure out what kinda cam it is
Reply #373
Quote from: daboss351;221335
Water leakage into the combustion chamber? I can't tell if it's on the intake or exhaust valve as the pic is dark.
Reply #374
intake valves cause they are the smaller valves
