Topic: The "Stinkin Lincoln" is being striped!!! (Read 53360 times) previous topic - next topic
Reply #120
Originally posted by boss351:
I was told i could swap the ring over
You can, but since it's pressed on you have to knock all of the studs out of the rotor and carefully tap around on each stud until the ring comes off. I used a PVC 2"-3" adapter with a cap to drive the ring on the new rotor. Make sure the ring is on the new rotor the same amount it was on the old rotor. If it's too far out of range the sensor won't be able to pick it up.
Matt
Reply #121
Quote from: 5.0 bird;184626
THANKS!!!!
I'm thinking about taking it to a machine shop so I don't risk messing it up, because I tend to get impatient and i don't want that messed up. I'm gonna try with the rotor on the other side and if i get it off no problem then I'm good.
Reply #122
Swaped the ring today
new rotor on pass side
new pads in
caliper painted
new strut in
new bearings and seal
Before
after
Now drivers side tomorrow, and new rack in.
only problem is i think the rotors kick the wheels out more... I dont think it will be a issue.
Reply #123
Front brakes are DONE
power steering is DONE
H pipe is half in
Well I can walk outside put the keys in and start it!!
Just doesnt stop well. Next step is BRAKES!!
The gutted cat h pipe sounds INSANE on the thing. Man do my neighbors HATE IT! I let it run for 10 mins to heat up, and test stuff Ive never tested. And I had one compliment me on it, and another yell cause I chucked a few revs. Needs lers and tails!
Re kinddled my love for it by backing it up and lighting the tires up, catches posi too, so the rear end is good! Long 4 day weekend so I intend to be able to drive it soon!
Reply #124
What els does  it need before it meets the road?
Take a pic of it. I've never seen it before
Reply #125
fuel lines fixed/replaced?
1979 Ford Fairmont
[/B]
Reply #126
Fuel lines are friday. I have to get the car back up in the air for the brake line leaks and I'm gonna pull the lines then too.
Whats left:
Fuel lines
2 brake lines
rear brake rotors and pads
passenger side H pipe section
Flow tubes
lers
tail pipes
Other little things. The list is shrinking fast!
Reply #127
Sweet, making good progress there! I wish I could reinstall cats into my H-pipe - ed droning is killing me!
Reply #128
Reply #129
Doin good there bubba,Is that the mac H your hookin up?
Still got the lers from it,You pay the shippin there yours.
Lookin good Mason, your gettin there.
Reply #130
Figure out shipping, re send me your address, and its a deal!
It fits GREAT, a little leak at the header but its not positioned right so thats why. I only ave the drivers side on at the moment, man o MAN is it scream!
Reply #131
nice car. thats an 88?. i was looking at an 87 a couple years back to replace my cougar but could you believe, it had more rust than mine.
they ride really smooth.i always keep an eye out for them.
Its hard to find a car with chrome bumpers on it . 1 day i'll find the one i want.
Reply #132
Yea that pic makes it look way better then it is. I payed 540 for the car, and its worth that, maybe less, but it should be a nice first car.
Finished up the h pipe install today. Ended up snapping the o2 sensor off to do it, so I need new o2 sensors tomorrow!
Reply #133
Reply #134
wtf was that? sounded like listening to a tractor run over a cordless phone with bad reception.
1979 Ford Fairmont
[/B]
