Topic: Hmmm I wonder... (Read 25712 times) previous topic - next topic
Hmmm I wonder...
hope your going to build up a bad ass cooler for that setup. i deffinetly give you props for giving it a shot! im a pessimist so i dont think it will work. good luck though.
~John~
Hmmm I wonder...
It already has a big frount mount intercooler and methanol injection. And if that is not enough the n2o will defenetly cool it down.:hick:
87 T-Bird turbo'd and supercharged and if things call for it juiced. :evilgrin:
88 Turbocoupe t3, 4.10's, Daily driver
Hmmm I wonder...
if you need 4 power adders on one motor, you might want to find another car. or invest in bailing wire.
1979 Ford Fairmont
[/B]
Hmmm I wonder...
LMAO:flip:
Hmmm I wonder...
Quote from: 32VFoxBird;143319
atleast let him try...  it is HIS car :flip:
Hmmm I wonder...
 thats a little ruff isnt it...
Hmmm I wonder...
you're right, and good luck with it. im sure you'll impress us all, when its done.
1979 Ford Fairmont
[/B]
Hmmm I wonder...
I'll bet $10 to a donut he blows the heads off it in 3 runs. :D
Hmmm I wonder...
Quote from: *MAYHEM*;143327
that much compression, all his internals will turn into one chunk of iron.
1979 Ford Fairmont
[/B]
Hmmm I wonder...
Well i was running 25psi turbo alone I want to run the same that's until I buy the 3.5bar map sensor and run 30+psi.
Hmmm I wonder...
Quote from: 88cat;143314
Well yea I could find a smaller turbine housing but I already had the sc and cost me lil to nothing to mount it. Also I want to prove wrong the ppl that say that this combo would not work. And last reason I did not went smaller housing is because im 19 and currently dont have a job.
The combo can work....
http://www.hilmersson-racing.com/start.asp?show=ea
Oil changes are gonna be a bitch.  Nothing like having to remove the SC to to add oil...
Hmmm I wonder...
I thought about the oil changes and everything and I will be adding my oil trough the back breather. But of course my hood will not close.
Hmmm I wonder...
Reminds me of VW's new... I think it's called Twincharger system.  Uses a SC for low-end torque and a turbo for high-rpm power.  All computer controlled, of course.  They had a 1.8, 2.0, and 2.2, IIRC.  I think I remember from what I read about it, it was over a 100hp-per-liter setup.  Which isn't really earth-shattering, but it's pretty impressive for a V-dub.
Hmmm I wonder...
It can work...I just don't understand why people think they need to run a turbo with a twin screw blower....it's a freakin' positive displacement supercharger...it won't stop making boost on that 2.3 at any rpm...low-end, mid-range, top-end...doesn't matter...sell your turbo and make your car a little lighter...you'll be faster.
Hmmm I wonder...
I'm just wondering, won't the SC actually slow down the airflow when the turbo is really boosting in high rpms?  Simply, won't the turbo be sucking at the slower-moving blower?
